Battle of Britain build part 3 - Spitfire! (Revell 1/32 new tool Spit Mk.II)
Finally got some paint on the 3 'wheels up' Spits. The 3 aircraft in question will all be from 610 sqn ,which I know is a very well known BoB sqn but was based at Biggin Hill during the battle and therefore interesting to me (Biggin Hill is just up the road fro me). The profiles are shown below:
2 aircraft are finished in the B scheme with DW S (R6686) in the A scheme.
Below are the 3 models with the camouflage paint on (I apologise for the quality of the photographs as there was no natural light whatsoever. The lighting in the room has unfortunately burned out some of the detail in the paintwork but should be apparent when I shoot these properly on completion).
Holy shit this is simply some amazing and beautiful work . Your model skillz is just awesome . The attention to detail is simply realistic. I love what you have going on and awesome work on the office and the exterior pain. Please keep the kick ass work coming
Cheers Brian
PS I also have this kit and look forward to building
And finally we have some primer on the 2 going in the dio, plus pre shading. The 3rd Spit (photo Spit) is ready for masking and should be primed this weekend.
Hopefully this weekend we should have some top coat on them. It's been a while since i painted an aircraft Dk Green and Earth and I'm strangely excited about it. I'm also going to be painting all the markings apart from the serial numbers
Hope to get a bit done this weekend.
P
ps. Thanks everyone who has commented on this rather stop start build.
Really nice work Paul, do you use airbrush for the preshading?
Hi Phikoleoputra. Yes, the preshading was airbrushed using my Iwata Custom Micron AB, Life Color paint thinned approx 2:1 paint to thinner, pressure around 18psi. Hope this helps.
Hi Brian, the kit is really nice to put together, it will need a little work to backdate it to a Mk1 (should you want to) but nothing too taxing. I'm pretty sure you'll enjoy the build.
Thanks everyone for the comments should have some markings on these 3 by the end of the day.
I wanted to post some progress on the painting of the 3 'wheels up' Spits today. I managed to crack and get 1 of the 3 to a stage that is worth reporting on.
And here it is, DW O with nearly all it's markings on ( only tail fin flash to go).
Port side
Starboard side
I'm fairly happy with the results I've got from masking. They are a bit bright at the moment but will tone down somewhat when I apply the weathering stages. They also need a bit of tidying up here and there but generally I'm happy with how it went. Masking and painting aircraft markings is a time consuming process though and I wouldn't recommend it for all models. That said, nothing beats this for a painted on look and it certainly gave me a real insight into how difficult it is to squeeze on these simply huge markings onto the fuselage of the Spitfire! I read somewhere that the guys that sprayed the markings on the real aircraft had to stagger the fuselage roundels (they are not symmetrical on both sides) just so they could fit the DW on the starboard side! And that's exactly what I had to do!.
Anyway, I hope you like the aircraft so far. Tomorrow DW O should be joined by his buddies DW K and DW S!
Very, very nice Paul what a difference those decals make they are really come to life.
Trying something new with these builds. The markings aren't decals I'm sirbrushing the roundels, flashes and codes on. I guess I can take your not noticing as a sign that the mask work is ok!??
