That is awesomeeeee preshading. Did you preshade the panel lines with flat black then spray the whole thing with olive drab????
Leo
I do not use pre-shading but post-shading.
I did not take pictures of the process with Olive Drab but after having painted Olive Drab I used a mixture. Olive Drab with yellow, the ratio 1 + 0.5 and about 80% thinner. Apply this mixture inside the panels.
As the Olive Drab is a dark color, I used black as well with 80% thinner and apply on lines of the panels.
Then apply the two mixtures again. In the wings in flight direction. In fuselage vertically.
Here the process but with the Neutral Grey.
Neutral Grey.
Lights.
Shadows.
Neutral Grey.
Lights.
Shadows.
Hope this helps.
Regards
ajcmac
Thanks mate, it's gonna be tricky for post shading. I'll try preshading fist then.
