Looking great. If I may say I think that the white camouflage was a type of emulsion. I think that it would wear away rather than chip. I think the effect you are looking for is like a really old painted wall where the paint has worn off.
Looking great. If I may say I think that the white camouflage was a type of emulsion. I think that it would wear away rather than chip. I think the effect you are looking for is like a really old painted wall where the paint has worn off.Ian M
So, in your opinion, paint all the camouflage with the option B should be correct? O_o
I tend to prefer A because, as Ian has mentioned and I'm sure Steve wil confirm, most winter camouflage was simply white emulsion slapped over the original camouflage. The effect you really want then is white paint, washed away from the two tone green below. I have seen pictures of tanks with quite a lot of the white simply washed off making for a very interesting effect! I think A is closest but I think washed over in streaks with thin white and grey washes.
By the way what you have done so far is simply beautiful. Poetry in paint!!
Regarding winter camo I'm not an expert so I went to search for images. I saw that there are different style but it looks the camo was mainly applied with brushes (brums) and kind of faded.
Effect a is perfect for chipped enamel, but doesn't look right overall.
Effect b is perfect for old cracked paint. From the close up it doesn't look right either, maybe looking it from distance it is. But the effect is great (was the hairspray still wet?).
