Junkers Ju87B-2 ‘Stuka’ Scale 1/24
  • Alan 45
    • Nov 2012
    • 9833
    #331
    Originally posted by \
    Reader of this thread will be aware that I did a small thing for Polux by sending him the rudder from an old and broken model in my loft. Today I got home from a period working abroad to find a box packed with goodies from Catalonia. In an amazingly generous gesture Polux has sent me three (yes three) 1/72 kits, completely unsolicited, for me to build or ruin in my usual way I just wanted to say a public 'thank you' to Polux and that I'm looking forward to having a bash at them. I will of course keep everyone posted.
    That's a very nice gesture I always say what goes around comes around
    • flyjoe180
      • Jan 2012
      • 12463
      • Joe
      • Earth
      #332
      Awesome, that is a great gesture Polux. And Steve thought he had finally escaped the world of 1/72. Time to crack out those reading glasses
        Not very clear but there are one or two pictures here that you can see the exhaust stubs on:http://aircraftnut.blogspot.com/2014/05/back-to-ju-87-stuka-part-3-variants.html
        Very interesting link!!!
        I can see the exhaust and some lovely winter camouflages!!
          Not, not!!! Thank you to you Steve
          Just hope one day I can help you in the same way that you have done
          Regards
          Polux
            Thats awesome of you both Polux and Steve! Pipes are looking good Polux,I have always struggled to get the right 'look' on those myself.
            • stona
              • Jul 2008
              • 9889
              #336
              It's a tricky business, exhausts.
              First the stubs were made from an alloy, not a cast iron or similar, and didn't oxidise to an overall rusty look so beloved of Airfix instructions.
              Secondly they were rather obviously exposed to extreme temperatures and the resulting discolouration or even burning (I remember a photograph of a Lancaster in which the stubs and part of the shroud have clearly burnt through).
              Thirdly the fuel used and way in which the engine is run had an effect on the deposits inevitably coating the stubs.
              Finally the exhaust stubs might be subject to some kind of specific maintenance regime, as was certainly the case for the Luftwaffe.
              Add all that lot together and you can see why modellers get confused!
              References are very hard to come by, particularly in colour. There are a few war birds which use WW2 fuel formulae and therefore reasonably replicate the colouration and deposits produced by their war time counterparts. I posted some pictures of a Merlin like this somewhere.
              Otherwise we can make estimations. Allied fuel had a very high lead content and when engines were run lean, as in bombers trying to get maximum air miles per gallon, a very light grey/white deposit and stains were produced. When run richer, as in a fighter using maximum everything, the deposits would be darker. German fuels were made quite differently and the staining generally appears very dark. This was why black exhaust panels and other black areas were often painted behind the exhausts. The stubs themselves were also blacked.
              In the factory the exhausts were finished in the regulation black with a product called Kemik Schwarz.
              Initially the stubs were to be maintained with this black compound, but later simply rubbing down with engine oil became an acceptable maintenance regime.
              These look black.
              But it was not always the case. Exhaust stubs may not have been at the top of a hard pressed ground crew's to do list.
              I still think that the original black colour is usually discernible and I always use a dark grey or metallic black as my base colour.
                Thanks for sharing this Steve.
                I think the picture before the last gives a good idea. On 1/24 scale would be interesting also distinguishing the Matt from the shiny part.
                One question regarding material, were exhausts of all planes made of alloy?
                Francesco
                • stona
                  • Jul 2008
                  • 9889
                  #338
                  Francesco
                  I don't know what alloys they all used. Rolls Royce used one of the 'Inconel' alloys (don't know which) that have a maximum of about 10% iron, hence a rusty colour is not likely. Daimler Benz also used a Nickel alloy, but I don't know its composition. I believe the Germans had problems with their Nickel supply later in the war, despite supplies from Finland, so it may well have changed. Nickel is certainly a strategic material, I remember seeing a table about it in the USSBS....might go and look it up
                  Here's what a Merlin 'fish tail' exhaust stub looks like when you dig it up and wash the mud off it after 70 years.
                  And it will clean up to something like this.
                  Obviously something that was iron and would rust on an aeroplane in weeks or months would not survive like this for many, many years.
                    Wow!
                    Now we have all kind of information and photos about the exhausts
                    The problem is on each photo they look different...
                    I have some ideas, so I will try new paint "combinations" like Trey, I think the exhausts are a very important part of the model as well
                    • monica
                      • Oct 2013
                      • 15169
                      #340
                      your so right Polux, and do take into account,were the plane was to the grim and rust on the exhausts
                      if it was wet alot of the time before it was started and flown in rain it would heat and burn in a diffidence way to one in a dry heat,
                        Yep!!
                        I cannot post any photo of the material, yesterday a "super nova" storm left all my little village without phone line . Now I'm posting with the I-Phone
                        This afternoon I have gone to the city and bought the needed paints (RLM 71 and RLM 72), and tape mask..not one, two!!!
                        Seems tomorrow I will can return to this one again!
                        See you tomorrow
                        • ojays
                          • Oct 2011
                          • 1713
                          #342
                          I know that the pics are B/W but does show a difference in tones/shades.
                          Or you could change the exhaust completely if not happy with the colour
                          [ATTACH]87414.IPB[/ATTACH]
                          [ATTACH]87416.IPB[/ATTACH]
                          [ATTACH]87427.IPB[/ATTACH]
                          Gregg
                          • stona
                            • Jul 2008
                            • 9889
                            #343
                            Any info on that last picture? The Ju 87 looks to be 'under new management'.
                            • ojays
                              • Oct 2011
                              • 1713
                              #344
                              Any info on that last picture? The Ju 87 looks to be 'under new management'.Cheers
                              Sorry Steve, the only information with the photo, was that it was Captured in 'Saltzburg Austria 1945'
                              Gregg
                              • stona
                                • Jul 2008
                                • 9889
                                #345
                                Sorry Steve, the only information with the photo, was that it was Captured in 'Saltzburg Austria 1945'Gregg
                                Thanks, I'll have a dig. Thing is Salzburg was 'liberated' by the Americans and those guys don't look American.
