Engine now built and just got to paint it , it when's together quite well but all the parts needed filing but I didn't get any major gaps that needed filling and those that are there will be covered once the engine is in [ATTACH]84814.IPB[/ATTACH]
Well here is the completed engine all painted , this was a bit boring everything but the exhausts and engine brackets was black so I just added a couple of burnt pips to give it a bit of detail and I dry brushed with dust grey to give it some wear and highlights [ATTACH]84827.IPB[/ATTACH]
For a bit of further inspiration here's a picture of the exhausts on a Merlin engined war bird. It's a Spitfire but uses a fuel formula close to WW2 specifications, so it is reasonable to assume that the colouring/staining would be similar too.
I reckon yours are close, maybe a little dry brushing?
I'm thinking to paint mine with some weathering (chipping effect on the soil), anyway I have to look...I see some photos on the web, and everybody paint free...as the engine!
If you want can start it together and share some tips
