Pleased you like it! Airfix have done such a fantastic job on it, it would be difficult to make it look bad. Worth the addition of the PE belt though just to finish it off.
Just a quick update for you. I reckon its taken about 3 hours over the course of the week to get to this stage.
[ATTACH]86352.IPB[/ATTACH]
[ATTACH]86354.IPB[/ATTACH]
I think I made hard work of the wing root. I don't know how but it was perfect when I dry fitted it but somehow I ended up with a small step!!!! More care to be taken next time me thinks.
The only issue I have found with the kit itself is the armoured fuel tank cover. It has been referenced in the Airfix magazine review and I took the authors advice and left the cockpit tub loose inside the fuselage to allow for adjustment but this part still required some serious thinning with the Dremel to get an acceptable fit.
The wing strengthening strakes were simple to remove with a new chisel shaped blade and some light sanding being careful not to damage the other detail on the wings.
A little bit of filler here and there and few panel lines re-scribed and all in all fairly straight forward assembly job.
Looks very good Jason. I know what you mean about dry fitting vs glue sticking! For some strange reason, parts often misbehave once they have a drop of cement on them!
Thanks for the comments chaps. You gotta love acrylic paint on a warm day, it dries so fast. Managed to have my first proper crack at pre shading.
[ATTACH]86370.IPB[/ATTACH]
[ATTACH]86371.IPB[/ATTACH]
[ATTACH]86372.IPB[/ATTACH]
That is actually Sky but I couldn't get the lighting right. It looks more effective in the flesh and once its got a wash in the panel lines I think I'll be happy with it. Topside to do next.
