Trumpeter 1/48 Westland Whirlwind (Not the Helicopter!)
  • Dave W
    • Jan 2011
    • 4713
    #31
    I
    Originally posted by \
    I would love them to produce a 32 scale Whirlwind. You have made a great start Dave.I have some HGW and RB productions fabric seatbelts to try and they suggest not using superglue but Gator Glue or similar.
    I didn't get as far as using glue.I first crumpled the harness carefully as instructed.The problem came when I tried to thread the buckles on.With hindsight I should have ignored the instructions and threaded the buckles on first.
    • Dave W
      • Jan 2011
      • 4713
      #32
      Considering it was axed at least twice and finally a limited number were built to use up parts and the available Peregrine engines it did do okay. It was a good aircraft at low level, but this wasn't really what was needed in 1940 and thereafter.Dowding, by the way, didn't rate it at all and had a very low opinion of Westland as well (related to problems with the Lysander).
      The point made in that link forced and rushed development is valid. The Whirlwind was a very advanced design as it came off the drawing board and there was little time to properly sort out problems like those of the tail wheel, exhausts, slats, never mind the Peregrine engine. The latter was nowhere near as bad as some would have you believe, but there were problems.
      It's also worth remembering that problems at Westland in 1938 caused a loss of confidence in the Whirlwind, which had been designed in early 1936 and still hadn't flown. This led directly to the ordering of 300 Beaufighters, sight unseen, though based on the Beaufort, in February 1939.
      I guess as neither of us was around when the Whirlwind was in service, we can only draw conclusions from what we have read about it.
      • stona
        • Jul 2008
        • 9889
        #33
        And what the RAF/Air Ministry/Westlands/Squadrons/the men who flew it wrote and said about it
        This what Dowding thought of the Whirlwind, in a letter written to Lord Beaverbrook, the head of the newly established Ministry of Aircraft Production (MAP) on 1st July 1940.
        "The pilots like them (although this may be largely due to their relief in getting away from the Blenheim); and they may be worth their weight in gold in the near future as being almost the only fighter aircraft capable of attacking tanks from the air. Against them is their very high approach and landing speeds. Pilots tell me that they have to bring them in at 110 mph and, even then, the controls are 'sloppy'. This means that they can probably never be used at night. Then again, if the Lysander is any criterion, we must expect an infinity of trouble with cowlings, fittings etc., unless the firm has learned wisdom from past experience. Further, I think that it is a very extravagant design By this I mean that it takes two engines to lift four cannon guns, whereas the new Hawker fighter [he's referring to what would become the Typhoon] should be able to lift six with one engine and give a similar performance with a lower landing speed. Altogether, I feel that we may be very glad indeed to have as many Whirlwinds as we can get in the near future both as anti tank weapons and in order to attack bombers as they become less and less vulnerable to rifle calibre machine gun fire, but we shall be glad enough to drop them when the Hawker fighter comes into heavy production."
        Shortly after this Dowding ruled that the Whirlwinds, which had been undergoing service trials with 25 Squadron, should go to 263 Squadron. The first were delivered on 3rd July. Dowding soon got his predicted 'infinity of troubles'.
        In that month alone rivets failed in the outer slat shells.Slats were jumping of their sprockets. Welds were failing on the carburettor intake ducts. Wingtip fairings were cracking after as little as ten hours flying, this seriously alarmed the pilots who feared that a wing tip failure might jam an aileron with almost certain fatal consequences. Tail wheel oleos collapsed, sometimes cracking the rear bulkhead. The oleos also needed re-pressurising weekly.
        As a result of this FO Bertram Grant (263's engineering officer) in consultation with Sqn Ldr William Disbrey (13 Group's Engineer Officer) grounded the Whirlwind until Westland could supply improved parts, particularly the wing tips.
        At a Fighter Command conference at around this time Dowding ordered that the Whirlwinds 'should not be thrown into air combat' since in the event of enemy tanks landing in Britain they would be invaluable in an anti tank role. Once modified wing tips were fitted 263 Squadron concentrated on making the cannon installation work reliably (yet another problem) and on practicing ground attacks.
        This was limited by repetition of the July problems. In fact, during most of August, none of the Whirlwinds were serviceable. In September they managed 55% serviceability but problems with the cannon persisted. Shell ejection problems caused regular jams and there was also damage to the aircraft's nose cone. The squadron bodged up some reinforcement and Westland eventually produced a 'quick release' reinforced cowling.
        The slat problem persisted with sprockets being stripped, eventually they were simply fixed closed.Other problems included fractured hydraulic pipes, put down to poor workmanship at Westland. Fuel tank sealant came loose and blocked fuel filters causing in flight engine failures, also blamed on Westland. The canopy Perspex cracked along the top seam and a new design was developed by the manufacturer. The cooling system was found to be prone to corrosion.
        I could go on, but suffice to say that by the end of October Dowding wrote to Beaverbrook, bearing in mind that any invasion threat complete with German tanks on the beaches was gone, concluding. 'It therefore becomes necessary to give careful consideration to the question of whether it is worth while persevering with the type at all'.
        For a 1936 design it was a remarkable aeroplane, it's always been one of my favourites but to imagine it to be comparable with the Spitfire, Hurricane or later cannon armed Typhoon would be unwise. Despite the long gestation period it was rushed into service seriously 'underdone' and never really recovered.
          As always Steve a really interesting read. Many thanks for putting things like this together I do enjoy reading them.
          • Dave W
            • Jan 2011
            • 4713
            #35
            Still, must gave been an amazing aircraft to fly when it came into service.and that armament of four 20mm cannons ....Imagine pulling the trigger for the first time after only firing riffle caliber machine guns.
            • stona
              • Jul 2008
              • 9889
              #36
              Absolutely, and all four right in front of you rather than out on the wings!
              • Dave W
                • Jan 2011
                • 4713
                #37
                Having been put firmly in my place by Steve,Ive decided its best to get on with the build and leave the history to him!.This kit is lacking a few details.Which is a bit disappointing considering it cost nearly £30.Theres no gun sight ,no brace behind the seat back and no wing tip lights.For the lights Ive cut the shapes out of the wing tips and glued clear sprue in their place.Tomorrow I will sand and polish them to shape.I need to research the gun sight.if it's the same as the Spitfire Ive got one in my spares box.Ive also done the first round of sanding.Some more to do on the engine cowlings.
                [ATTACH]87737.IPB[/ATTACH]
                [ATTACH]87738.IPB[/ATTACH]
                [ATTACH]87739.IPB[/ATTACH]
                [ATTACH]87740.IPB[/ATTACH]
                [ATTACH]87741.IPB[/ATTACH]
                  Nice update Dave ,I like what you've done with the nav lights and clear sprue thats always a nice touch often overlooked(myself included). What kind of putty are you using on the engine nacelles?
                  • Dave W
                    • Jan 2011
                    • 4713
                    #39
                    I used squadron green first and am finishing off with Mr Surfacer 500
                      This is coming along nicely Dave.
                      • BarryW
                        • Jul 2011
                        • 6010
                        #41
                        Excellent Dave. A good idea with the wing tip light. Personally I tend to just paint them and then apply gloss to simulate the glass.
                        • stona
                          • Jul 2008
                          • 9889
                          #42
                          Looking very nice. Good job on the wing tip navigation lights.
                          If you wanted to make coloured covers then rather than painting them (I use Humbrol 'clear' colours) you can use the same method of inserting a piece using the appropriately coloured plastic from a tooth brush handle. I have done this myself, but tend to be too lazy these days. I also have an electric toothbrush which I can't cut up
                          If you are stuck with plain plastic and don't want to cut out and make the lights as Dave has done, you can make a reasonable job by painting the light silver before applying the colour.
                          • Dave W
                            • Jan 2011
                            • 4713
                            #43
                            Looking very nice. Good job on the wing tip navigation lights.If you wanted to make coloured covers then rather than painting them (I use Humbrol 'clear' colours) you can use the same method of inserting a piece using the appropriately coloured plastic from a tooth brush handle. I have done this myself, but tend to be too lazy these days. I also have an electric toothbrush which I can't cut up
                            I know about the coloured toothbrush handle trick but keep forgetting to buy some!.
                            • stona
                              • Jul 2008
                              • 9889
                              #44
                              In the old days I used to deliberately buy red, green, blue and amber tooth brushes which covered me for almost every eventuality! Now, with electric tooth brushes, I don't have the option. I've just had a look in my den to see if I have any of the old handles are left but there's no sign of them. Probably culled in one of my big clean outs
                              I admire you using this method, I always found it a pain in the whatsit sanding the inserts to shape.
                              • Dave W
                                • Jan 2011
                                • 4713
                                #45
                                Ive sanded the wing tip lights to shape.Then I added a gun sight left over from an Airfix Spitfire kit.Not sure if its the right type.But it's better than nothing at all.Ive also made a brace for the seat back.Then I sanded the second lot of filler on the top of the engine cowlings.
                                [ATTACH]88012.IPB[/ATTACH]
                                [ATTACH]88013.IPB[/ATTACH]
