This one has been in the stash a long time and I've put off building it ,mainly due to reported fit issues. The usual start at the office
I made some harness straps from painted strips of masking tape and then added some left over P/E bits from the spares box.
The intake tubes seemed long to me so I cut them down a bit
Test dry fitting of the nose cone seemed sketchy so I added some small square stock to act as an alignment guide. I filed an angle on the top surfaces of the square stock to avoid fit issues
The fuse fit so far seems okay,things will soon tell when the sub assemblies go together ,or not. Hoping past reviews I've read about the ill fits somehow wo'nt manifest themselves.
I'm going to take some liberties with the paint scheme as this is a what if Luft 46 subject anyway,cheers Trey
