Great progress Dave , its going to be impressive when its done. Ive used aerosol primer as a finish a good few times , if the colours right why not? seems daft to me to overspray it with exactly the same colour. The tu 160 blackjack was entirely done in halfords white primer and their grey one is a great match for US neutral grey . oh and dont forget the HUD ! cheers tony
Gern's Phantom
Originally posted by \With such a simple paint job -
Except I forgot about the weapons pylons. I gotta fix those before I paint so I can tidy up all the joints and seams - but they've already been decalled! Normally I'd cover the decals with bits of foil or similar, then fix the foil to the surface with masking tape round the edges. I wrapped a bit of polythene around the nose of the fuel tank so that's no problem:
[ATTACH]88563.IPB[/ATTACH]
But on the pylons, the decals are so close to the edges and space is so restricted I can't do that.
Any idea how I can mask the decals while spraying - and then remove the masking without also removing the decals? They've already been sealed with Humbrol Matt spray varnish but I don't know if this would be strong enough to protect them from any masking adhesive.
Gern
Attached FilesComment
Maybe masking fluid dave? or some Tamiya tape but stick it to your hand first to take some of the tack off so its not too sticky. I'm sure a man of your calibre will sort it (that reminds me , I used to be a circus performer you know, Human Cannonball , loved the job but i got fired (!) after only a week , they said I wasnt the right calibre for the job !!!)ok i'll get me coat , cheers tonyComment
Originally posted by GernYeah. Sure.Except I forgot about the weapons pylons. I gotta fix those before I paint so I can tidy up all the joints and seams - but they've already been decalled! Normally I'd cover the decals with bits of foil or similar, then fix the foil to the surface with masking tape round the edges. I wrapped a bit of polythene around the nose of the fuel tank so that's no problem:
[ATTACH]89164[/ATTACH]
GernComment
OK. That's got the building part done. Just got to touch up some small gaps on the pylons and then I'll be painting.
[ATTACH]88962.IPB[/ATTACH]
[ATTACH]88963.IPB[/ATTACH]
While I'm here, I have another question. I've got another kit on the go (details later) and had to clean up a seam on the canopy. It filed off OK and I used a succession of finer grits to clean the sanding marks. I finished off with some toothpaste - as I don't have any polishing compound - and a soft cloth and got it looking OK. I've heard that canopies can be improved with a coat of Johnson's Clear, so that's what I did - brush painted some on. Does anyone know why my Clear has dried with a faint but very noticeable 'orange peel' effect?
Gern
PS I was sure I'd replied about the decals masking - unless I put it on the wrong post or summat! Not sure which method to use yet, I'll maybe do some spare decals on a bit of scrap using the same paints etc and try out the suggestions.
Great work Dave, I didn't realise just how big this was till I saw it on the printer. Fantastic...
AndyComment
Originally posted by \OK. That's got the building part done. Just got to touch up some small gaps on the pylons and then I'll be painting.[ATTACH]89614[/ATTACH] [ATTACH]89615[/ATTACH]
Gern
PS I was sure I'd replied about the decals masking - unless I put it on the wrong post or summat! Not sure which method to use yet, I'll maybe do some spare decals on a bit of scrap using the same paints etc and try out the suggestions.Comment
Thanks for the nice comments guys.
Tony - I'm going to do just what you said. Soak them in Clear for a while then drain and let them dry in a box with a lid. I have no idea what's caused the Clear to act as it has - maybe I didn't clean off all the toothpaste I used for polishing?
I agree that white tack will probably do the masking I need, but I still want to try a test piece. Some of the decals tore while I was putting them on so I know they're rather delicate.
GernComment
OK. I did exactly what you said Tony - and got absolutely nowhere. If anything the 'orange peel' effect was worse.
I've looked at the parts under my magnifier and there is some sort of dirt/grease on the plastic. I've tried the following:
Neat ammonia (recommended for removing Klear)
Two general purpose household cleaners
Windowlene
Washing-up liquid
Liquid hand soap
Concentrated bleach
Vinegar
Any suggestions guys 'cos the dirt is still there!?
GernComment
OK try this Dave. Take it back to square one, soak the canopy in klearfor a few hoursvthen when you take it out rinse it in soapy water straight away , this should hopefully get all the klear off it. Then its a case of looking at the plastic and seeing if there's anything left on it like grease, toothpaste etc. Let us know how you get on . tonyComment
