Revells 1/32 162 A-2 ,got started this weekend ,want to give a thanks to all for the great input about the color callouts ! The usual start in the office .The interior is rather spartan but I'll be adding bits as it goes together to remedy that
(Kudos to Dubster for the great link it was a huge help). The seal belts were tackled first,I used foil from a wine bottle cut up into strips then added some buckles and bits from the spares box
The nose gear assembly was missing the small return spring on the port side so I wound one out of a strand of small wire,more details will be added later. I plan to display it with the nose cone off I want to dress it up a bit
The IP is just the supplied decals with some canopy glue dropped on the instrument faces,I added the straps on the rudder pedals with the same wine foil as the harness
Starting on the engine next, still doing some research for the plumbing and accessories. cheers Trey
