He 162 A-2 Revell 1/32 completed !
    Looking good Trey! For my reference, what colour is RLM 76? It looks quite like a pale grey to me?
      That looks amazing so far Trey the work you have put into that engine alone is a masterpiece mate beautiful work so far.
      scott
      • Vaughan
        • Apr 2011
        • 3174
        #48
        Looking good Trey. Just a question how are you going to balance the He 162 without a nose cone there's nowhere to put any weights?
          Looking good Trey, looking forward to the next update
          • stona
            • Jul 2008
            • 9889
            #50
            It's a blue/grey though much less blue than the RLM 65 it replaced on fighters.
            It's one of the few colours that did show some variation from the standard, particularly late in the war.
              Thanks Steve!
              • flyjoe180
                • Jan 2012
                • 12390
                • Joe
                • Earth
                #52
                That's looking good Trey.
                  • 22770
                  #53
                  Great work Trey
                    Thanks Patrick & Scott !
                    Vaughan thanks and I was able to put the proper amount of lead just behind the seat,you can see it a few posts back.
                    Joe ,Ian thank you!
                    I went with a straight RLM71 and post shaded it with some very thinned RLM02 mixed with the 71 just to break it up. I'm hoping after a wash , filter & clear coat session it will darken up a bit,if not I'll just hit it with some pastels. While this copies the scheme in the instructions for 'White 1" its probably not very authentic,its fine for my shelf and I like the lines so I'm rolling with it.
                    Steve any input on color and scheme authenticity is most welcome. From what pics I've been able to find there seem to be 3 different lines between the top and bottom colors used ,all very confusing indeed.
                    • stona
                      • Jul 2008
                      • 9889
                      #55
                      There was an official scheme for the He 162, but as the at least FIVE different patterns and colours seen on those captured at Leck (including 'White 1' ) show it was by no means applied as a standard this late in the war.
                      Michael Ullmann reckons that 'White 1' was painted with upper surfaces in an over all RLM 81 and the instructions' high demarcation looks about right. The lower surfaces were RLM 76. The band around the front of the engine intake is reckoned to be yellow.
                      You've probably already seen this.
                      I've seen several people claiming that the earlier colours (70/71) were used on these aircraft. I have my doubts but you never know.
                      The official scheme was 81/82/76, promulgated in January 1945. The reason so many different versions are evident on the captured examples is probably the dispersion of manufacturing facilities and the painting of various component parts by several sub-contractors.
                      Here's the official scheme for what it's worth.
                        Thanks Steve ,I had'nt seen that photo before,nice to see a actual shot of 'White1'.
                        Finally able to squeeze in some bench time and had a epic a/b failure. Right in the finishing stages of a filter the a/b sneezed a big bunch of gobs on the tops surface. I had to go back and wet sand down then reapply some colors,the results are not as good as I would've liked but its better than it was.
                          It's a PITA when the AB does that! But you've saved the day & she's looking great!
                          Having the nose off exposes that lovely gear detail
                            Beautiful, simply beautiful. This really is a cracking kit and you have done it proud.
                            • flyjoe180
                              • Jan 2012
                              • 12390
                              • Joe
                              • Earth
                              #59
                              Looking good Trey.
                              • Vaughan
                                • Apr 2011
                                • 3174
                                #60
                                Looks great Trey, especially the engine, despite your problems with the AB. I notice that the gun bay door is missing is this intentional?
