BAE Harrier GR7 Op Herrick - Revell 1/144 - Complete
    Hello mates,
    Just started this new project.
    [ATTACH]90496.IPB[/ATTACH]
    The kit looks quite good and light years better than the Minicraft I used to build. You can see a snapshot down here.
    [ATTACH]90497.IPB[/ATTACH]
    [ATTACH]90498.IPB[/ATTACH]
    Big question here. Despite all my research I've not been able to understand if the LERX in the kit is 65 or 100%. According to some review it is 100 and it should then be reduced to 65. Any hint?
    Francesco
    Francesco, check out the Harrier SIG there is a list of the airframes and which had 65 or 100% plus everything else you need.
      • 22770
      It looks a good kit Francesco. I will watch you work your magic on this one
      • yak face
        • Jun 2009
        • 13841
        • Tony
        These newer Revell 1/144 toolings are excellent Francesco , I'm sure it will be a super build. Its going to be nice for you not to have to scratchbuild the interior too ! cheers tony
        • PaulTRose
          • Jun 2013
          • 6466
          • Tattooine
          tis is a nice little kit, did it a few years ago as a Spanish bird
          Per Ardua
            Thank you for your feedback mates.
            I started opening few air intakes and airbrake.
            [ATTACH]90755.IPB[/ATTACH]
            Still thinking if I should (am capable of) modify the LERX.
            Francesco
            • flyjoe180
              • Jan 2012
              • 12407
              • Joe
              • Earth
              Consensus online shows the aircraft presented in this kit should have the LERX at 65% on this one Francesco. Also, referring to the harriersig.org.uk the
              65% LERX fits low on the wing leading edge, are flat when viewed from ground level, have distinct flanges attaching them to the wing and engine covers and retain the fire access point in the wing root leading edges. When present with frogs eyes, the fire access point is blocked up.
              http://www.harriersig.org.uk/models/lerxv1.pdf
              Each serial number is listed with the appropriate LERX configuration.
                Yep Joe, you'right and thanks for the useful link.
                This is ZD404 so LERX 65% and no Frog Eyes
                [ATTACH]90780.IPB[/ATTACH]
                Now I need to find a way to reduce the LERX without destroying the model. Til now I found no one who made it on this scale.
                Francesco
                • flyjoe180
                  • Jan 2012
                  • 12407
                  • Joe
                  • Earth
                  Pleasure to help. That harrier site was my main point of reference when I made my two. I reckon the LERX could be converted. I would look at removing the kit ones. The 65% LERX looks to be flatter and obviously smaller, as on the box art. You could use plastic card to change it and blend it using putty. The frog's eyes on top can easily be removed (refer box art again compared to the plastic). They are fire access intakes for the engine I think and should be removed and made flush with the fuselage top on your GR7.
                    Tons of useful info here, thanks again.
                    This is where I am.
                    Completed one intake
                    [ATTACH]91026.IPB[/ATTACH]
                    Completed LIDS fence and airbrake wells
                    [ATTACH]91027.IPB[/ATTACH]
                    Started working on the pit
                    [ATTACH]91028.IPB[/ATTACH]
                    Next will be opening the front LG bay and the other intake.
                    Hope you like it.
                    Francesco
                      Hi mates,
                      Short update and slow building, I know.
                      I've replaced the side panels, molded with the fuselage in the kit, made the airbrake, added the beacon under the fuselage and shortened the tail fin base.
                      In the picture you should also be able to see the front LG bay detailed yesterday.
                      [ATTACH]91212.IPB[/ATTACH]
                      [ATTACH]91213.IPB[/ATTACH]
                      That's all for now.
                      Francesco
                      • flyjoe180
                        • Jan 2012
                        • 12407
                        • Joe
                        • Earth
                        Good work Francesco.
                          Thanks Joe,
                          Almost done with the LERX mod
                          [ATTACH]91430.IPB[/ATTACH]
                          Francesco
                            • 22770
                            Your doing some great work there Francesco
                              Thanks Ian.
                              I was not happy with the LERX I made with metal sheet and remaking them with plasticard.
                              Hope to post more soon.
