Airfix 1/48 Mosquito mk6
    This is coming on very nicely Dave the guns look really good. I would have done it the way you have done sticking it all together and masking the barrels off.
      • 22771
      #47
      Looking very nice Dave
        • 18271
        A good way to mask those barrels is to use a stiff paper and roll it into a tube and slip them over each one then a blob of white tak on the end to keep them in place..
        • rickoshea52
          • Dec 2011
          • 4076
          • Rick
          #49
          Originally posted by \
          A good way to mask those barrels is to use a stiff paper and roll it into a tube and slip them over each one then a blob of white tak on the end to keep them in place..Ian M
          Some cotton buds have hollow stems, cut the bud off one end and maybe it will slip over the barrels.
          • Dave W
            • Jan 2011
            • 4713
            #50
            Tonight I've sprayed some primer on the model.I used Alclad White primer which is my primer of choice these days.It covers well and dries quickly.
            [ATTACH]93461.IPB[/ATTACH]
              • 22771
              #51
              That looks all white Dave ( sorry )
              • flyjoe180
                • Jan 2012
                • 12433
                • Joe
                • Earth
                #52
                It's looking sharp.
                • rickoshea52
                  • Dec 2011
                  • 4076
                  • Rick
                  #53
                  I really like the stuff.I filled the gaps between the engine cowlings and the undersides of the wings in the manner you described.Would have taken a lot more work with my usual squadron green.
                  Here's a video of what it can be used for.
                  • Alan 45
                    • Nov 2012
                    • 9833
                    #54
                    That's looking good dave in fact it's making me seriously think about getting the rebox , that tail looks much better than the tamiya one
                    • Dave W
                      • Jan 2011
                      • 4713
                      #55
                      The rebox is a mk16 with the longer two stage Merlins.Although I think they still include the original parts to build a mk6 in the kit.I would like to build one of those as well.
                      • Alan 45
                        • Nov 2012
                        • 9833
                        #56
                        I hope it does but if not I don't mind doing the bomber version
                        • Dave W
                          • Jan 2011
                          • 4713
                          #57
                          Got some more paint on the model tonight.The Airfix painting guide shows medium sea grey on the upper surfaces as well as the undersides. I thought the upper surfaces should be Ocean grey and dark green.A bit of research on the Internet shows Airfix were probably right.In doing a 418 squadron aircraft and although the Airfix decals are no good,the Monogram kit I'm also building has decals for an aircraft from the same squadron.The code letter red is too bright,so I will use some from my decal collection.But it does have a nice nose art decal for 'Lady Luck' which I will use.
                          [ATTACH]93644.IPB[/ATTACH]
                          [ATTACH]93645.IPB[/ATTACH]
                          [ATTACH]93646.IPB[/ATTACH]
                          [ATTACH]93647.IPB[/ATTACH]
                          [ATTACH]93648.IPB[/ATTACH]
                          [ATTACH]93649.IPB[/ATTACH]
                            Looking very good Dave really like the way it has come together and those barrels look good.
                            • flyjoe180
                              • Jan 2012
                              • 12433
                              • Joe
                              • Earth
                              #59
                              The beautifully restored Mosquito KA114 has the medium sea grey on the upper and lower surfaces.
                              [ATTACH]93650.IPB[/ATTACH]
                              The bomber versions appear to have worn the Dark Green/Ocean Grey over Medium Sea Grey undersides (the same as the Fighter Command day scheme) whereas fighter-bomber variants appear to have worn the overall Medium Sea Grey with dark green on top.
                              The MSG oveall with disruptive green pattern on top is in fact a Night Fighter scheme initially prescribed in AMO 644/42 "Camouflage Colouring and Marking of Aircraft" . A number of Mosquito FBVI were painted in this scheme. The standard day scheme was DG/DSG over MSG undersides and was also in use on FBVI. I guess it comes down to researching your chosen subject thoroughly.
                              • Dave W
                                • Jan 2011
                                • 4713
                                #60
                                [ATTACH]93961.IPB[/ATTACH]
                                [ATTACH]93962.IPB[/ATTACH]
                                Yesterday evening I masked the camo pattern.And tonight I've sprayed a coat of Xtracolour Dark Green on.If it dries this evening out in my cold garage I will put another coat on.
