Monogram 1/48 Mosquito mk2
  • Dave W
    • Jan 2011
    • 4713
    #31
    Originally posted by \
    No mate it's this one [ATTACH]96141[/ATTACH]I just got this off google
    That's the old Monogram kit reboxed then.The one I'm building here.Its not a totally accurate Mosquito.But if I hadn't just built the Tamiya and Airfix kits,I don't think I would have noticed!.
    • Alan 45
      • Nov 2012
      • 9833
      #32
      That's a relief dave I can use this thread to get around the problems when I build mine
      • Dave W
        • Jan 2011
        • 4713
        #33
        [ATTACH]95243.IPB[/ATTACH]
        [ATTACH]95244.IPB[/ATTACH]
        [ATTACH]95245.IPB[/ATTACH]
        [ATTACH]95246.IPB[/ATTACH]
        The undercarriage doors are moulded as part of the engine nacelles.If you want the gear down,they have to be carefully cut out then cleaned up.Door hinges are supplied as separate items.Ive masked the canopy frames this evening and glued it to the model.And I've glued on the wing tip lights.These needed a bit of plastic card to make them a better fit.The kits .303 machine guns are way over scale.So I've got some 'Master' brass barrels to fit in their place.On this build I've decided to fit them after painting and finishing the model.So I've filled the inside of the nose with scrap plastic.And I've filled the oversized gun ports.I will drill holes for the guns and fix with superglue at the end of the build.
        • Dave W
          • Jan 2011
          • 4713
          #34
          [ATTACH]95586.IPB[/ATTACH]
          Thought I would try out the spray booth I got for Christmas.Its very cold in my garage, so I used Alclad grey primer on the model.It doesn't seem to be affected by the low temperature and has dried as quick as usual and give a nice,smooth finish.
            This is coming along very nicely Dave.
            • Alan 45
              • Nov 2012
              • 9833
              #36
              Very nice dave
              I'm building that airfix one at the moment but I'm further along and already have the base colours on which means yours will look better than mine
              • Dave W
                • Jan 2011
                • 4713
                #37
                Very nice dave I'm building that airfix one at the moment but I'm further along and already have the base colours on which means yours will look better than mine
                I doubt it will look better than yours Alan.I may appear to be taking my time with this one.But the reality is I haven't had much chance to do much modelling lately.Family stuff keeps getting in the way!.
                • flyjoe180
                  • Jan 2012
                  • 12400
                  • Joe
                  • Earth
                  #38
                  That Alclad primer looks like good stuff Dave.
                  • Alan 45
                    • Nov 2012
                    • 9833
                    #39
                    Nah dave ive rushed mine and left out some filing and I got the underside colour wrong , i cose what I thought was a mid sea grey mate but ended up with a stone grey gloss and me and gloss don't get on so the surface is full of brush marks and will be difficult to weather , top side is fine but to much rushing for the 1/24 SSIG has made me do stupid mistakes
                    • Dave W
                      • Jan 2011
                      • 4713
                      #40
                      [ATTACH]95651.IPB[/ATTACH]
                      [ATTACH]95652.IPB[/ATTACH]
                      After a bit more filling and some more primer I have now got a coat of black on the model.for this I used Revell enamel number 9 'Anthracite' as it's not too black if you know what I mean.Ive also sprayed the prop spinners and undercarriage doors the same colour.
                      • flyjoe180
                        • Jan 2012
                        • 12400
                        • Joe
                        • Earth
                        #41
                        That anthracite works nicely Dave. You are brave storing it like that, I wouldn't sleep knowing it was at the mercy of those drawers.
                        • Dave W
                          • Jan 2011
                          • 4713
                          #42
                          It's in my garage and I'm the only one who goes in there.so it's quite safe.
                          • tr1ckey66
                            • Mar 2009
                            • 3592
                            #43
                            Hi Dave
                            Just catching up on a few threads I've missed.
                            Great work on a really, really old kit. I'm really looking forward to seeing this finished and joining the other 2. You will be photographing the 3 together won't you? It will be great to see the variants together.
                            Paul
                            • Dave W
                              • Jan 2011
                              • 4713
                              #44
                              Hi DaveJust catching up on a few threads I've missed.
                              Paul
                              Yes I intend posting a photo of all 3 together.
                                Before I comment on anything else; this was made in the U.S.A
                                Looks like it's coming along nicely ;-)
