Revell 1:32 Bf109 G-10
  • matto21
    • Apr 2014
    • 182
    Hello,
    I've just started my next build, Revell's 1:32 Bf109 G-10. I've never built a 1:32 model before, mainly due to size, cost, skill etc but recently decided to take the plunge.
    This isn't going to be a quick build, mainly due to the difference in scale!
    Work started in the cockpit as usual, all parts were sprayed mid grey over a black undercoat to allow some subtle shading [although it's not really visible in the photos].
    [ATTACH]93718.IPB[/ATTACH]
    I removed the moulded seatbelts and bought the Eduard PE set however, after thinking about it, I made my own belts using the buckles provided in the Eduard set. I think they look a little less 'flat' than the PE ones [but feel free to disagree!]
    [ATTACH]93719.IPB[/ATTACH]
    I used a combination of Revell and Airscale decals on the IP. I've added a drop of Klear to the dial faces [just visible in the photos below].
    [ATTACH]93720.IPB[/ATTACH]
    Here's where I am now - the cockpit has been matted down and partially assembled. If I'm honest, I'm really pleased how it's turned out so far.
    [ATTACH]93721.IPB[/ATTACH]
    I've also taped the fuselage together and it looks [and fits] great!
    [ATTACH]93722.IPB[/ATTACH]
    That's it for now, thanks for looking!
    Matt
    That cockpit looks great Matt! You might want to look for Vaughan's build on here - I think his was the G-6, but I guess both Revell kits are much the same.
    Patrick
      • 18266
      Dont think you have to worry about the skills part. You got that cock pit looking very nice!
      • monica
        • Oct 2013
        • 15169
        very nice start ,and have to agree with Ian,the cockpit looks great,
          • 22770
          Great start Matt
            Excellent paintwork, wash and subtle chipping effect on the seat.
            Fantastic cockpit so far!!
            • dave
              • Nov 2012
              • 1828
              • Brussels
              Good start, I may have to pinch the idea of a drop of kleer on the dials of the instrument panel, it looks good.
              • matto21
                • Apr 2014
                • 182
                I've bought the Barracuda replacement exhausts [mainly to avoid having to drill out the kit parts!] and they arrived today and look great. Undecided whether or not to use the cooling scoops that you also get in the set - they also look good but I don't know if I can be bothered!
                  If I can give you ONE piece of advice: get the eduard Brassin landing gear (bronze legs for the G-6, but they fit the G-10 as well) they're VERY well worth the money!
                  This coming from someone who's built the G-6 and the G-10
                    Lovely work on that cockpit Matt, looking forward to seeing more
                      superb paintwork !!
                        Looking great Matt, cockpit is lovely.
                        • matto21
                          • Apr 2014
                          • 182
                          Thanks for the comments and interest!
                          Today I've been able to assemble the fuselage and install the cockpit module. Both fitted really well and I only needed minimal filler. I've also fitted the Barracuda exhausts and these make all the difference in my opinion.
                          [ATTACH]94338.IPB[/ATTACH]
                          [ATTACH]94337.IPB[/ATTACH]
                          [ATTACH]94334.IPB[/ATTACH]
                          Thanks
                          Matt
                          [ATTACH]94335.IPB[/ATTACH]
                          [ATTACH]94336.IPB[/ATTACH]
                            Those exhausts look excellent Matt! Worth bearing in mind for when I tackle this kit.
                            • matto21
                              • Apr 2014
                              • 182
                              Some progress at last! Wheel bulges had noticeable sink marks which took some time to fill and sand [no doubt I'll need to do more once I've applied some primer!]. Wings have now been fitted to the fuselage:
                              [ATTACH]95876.IPB[/ATTACH]
                              Matt
