Matchbox 1:72 Supermarine Walrus
  • colin m
    • 8759
    • Colin
    • Stafford, UK
    Greetings all,
    I've been trapped in our utility room decorating ( I don't like decorating) so in between paint drying etc, I have started to build this 1973 classic from Matchbox.
    Laurie has just started and is making good progress of the Revell re-boxed version of the same kit.
    I did message Laurie to check he was OK with me doing the same build and he very kindly said go for it. So here I am, with a nice little build that should take me up to the 1:24 group build in January.
    [ATTACH]94441.IPB[/ATTACH]
    Interesting instructions.
    [ATTACH]94442.IPB[/ATTACH]
    For the exterior, I'm scribing and riveting, as there is little detail. The Trumpeter riveting tool works quite well, but I an wondering if the rivets will still be visible after a couple of coats of paint ?
    [ATTACH]94443.IPB[/ATTACH]
    [ATTACH]94444.IPB[/ATTACH]
    The interior is as dull as the exterior, so I've added a few little bits and pieces just to liven it up a bit.
    [ATTACH]94445.IPB[/ATTACH]
    [ATTACH]94446.IPB[/ATTACH]
    Of course, little will be visible when all sealed up.
    Right then, it could be time for a bit of paint.
    Colin M.....
  • tr1ckey66
    • Mar 2009
    • 3592
    Hi Colin
    I don't know - you wait for a Walrus for ages and then 2 come along all at once...
    Should be really interesting watching the 2 approaches to the same kit.
    All the best with the build
    Paul
    • Alan 45
      • Nov 2012
      • 9833
      My favourite float plane ive built the airfix one of these so it would be good to see the difference
      I have the smere 1/48 which is very basic
      • Dave W
        • Jan 2011
        • 4713
        Looking forward to seeing another rigging masterclass Colin.
          • 22770
          A very nice start Colin
          • flyjoe180
            • Jan 2012
            • 12417
            • Joe
            • Earth
            Nice start Colin. Look forward to seeing the rigging later on. A wee heard of Walruses
            • colin m
              • 8759
              • Colin
              • Stafford, UK
              So, here we are again. I've been a bit bad this week so didn't feel like picking the plastic up. In fact, I've been so bad I've been off coffee, tea, and alcohol. Wow, now I realise while I still feel so rough, I've just detoxed myself and didn't even realise it. idiot !
              Anyway, a little more has been done at last - and this was meant to be a nice little build before Christmas.
              [ATTACH]94852.IPB[/ATTACH]
              Dodgy pic using a phone, just too lazy to find a proper camera. This is the result of the trumpeter riveting tool. Good result, I'm just a bit concerned it will vanish under the paint.
              [ATTACH]94853.IPB[/ATTACH]
              I'm not too sure about wing alignment but I think old pics show the upper wing to be flat, so I've built mine on a flat surface and see how things line up now. I normally find old Matchbox kits have a great fit, this kit seems to be 50/50. The wings, engine have been great, but the fuse was quite a bit out and so had to be glued bit by bit.
              The holes have been drilled for the rigging, 56 in all, but I'm sure there's a few more to be discovered. Right, lets have a play with some alignment.
              • flyjoe180
                • Jan 2012
                • 12417
                • Joe
                • Earth
                Nice progress Colin.
                  • 22770
                  Looking good Colin and good luck with the aliginment
                  • colin m
                    • 8759
                    • Colin
                    • Stafford, UK
                    Thanks for stopping by gentlemen. So a little update. Christmas sort of got in the way but I did manage a bit of work yesterday. As the 1:24 scale GB is just around the corner I've tried to simplify this model somewhat. So, no time for camouflage, why use three colours when I can use one. So, it's the silver version I'm doing, true a bit boring, but being a bi-plane with a bit of rigging, I'm hoping that will add enough interest to disguise the single colour scheme.
                    [ATTACH]95183.IPB[/ATTACH]
                    Early yesterday, the priming was completed. All dried and sanded.
                    [ATTACH]95184.IPB[/ATTACH]
                    [ATTACH]95185.IPB[/ATTACH]
                    Painting completed and I'm pleased to confirm, despite my earlier worries, I haven't lost my rivets. Look, there they are, see ?
                    [ATTACH]95186.IPB[/ATTACH]
                    The very last job at midnight last night was to attach the lower wings. I like to attach things like wings or landing gear when I'm the last person to bed. I can then walk away knowing no one can knock or touch it in anyway. The big bonus here is next day, it's ready for the next round of building. I've attached the wings with a tiny amount of dihedral. I was really going for a flat fitment, but they seemed to want to create a natural dihedral so I went with it. I'm guessing the only problem this can cause me is I might have to reduce the interplane struts by a fraction of a mm. Which is much easier than making them longer than a fraction of a mm.
                    Right, just give me a minute whilst I slap the upper wing on..... !!
                    Colin M....
                      • 22770
                      Great work Colin lovely paint work and riveting detail
                      • colin m
                        • 8759
                        • Colin
                        • Stafford, UK
                        Thanks Ian, as I said, I wasn't sure if I would lose the detail or not, happily not.
                        OK, so a bit more than a minute, but the upper wings are in place. Using my patented Mk1 wing alignment tool.
                        [ATTACH]95187.IPB[/ATTACH]
                        [ATTACH]95188.IPB[/ATTACH]
                        OK so the wing alignment tool does look a bit like Lego.
                        Colin M....
                          Looking good, Colin, with all the panel and rivet detail. I don't think the silver scheme is boring at all - you only ever seem to see camouflaged Walruses (or would that be Walri?). This should really stand out from the crowd - unless of course you've got a vast collection of inter-war RAF planes.
                          • Dave W
                            • Jan 2011
                            • 4713
                            Looking really good Colin.Im looking forward to the rigging.
                              Excellent use of Lego Colin! This is a great thread, I'm sure the Walrus was one Matchbox kit I steered clear of as a youngster!
