My new project is Trumpeter MiG 32 ml, with its many glaring defects corrected with the Aires resin - cockpit plus drive bays and inlet separator plates Zactomodels, very few pieces of kit Eduard exterior and lots of buildings zero!
Drawings scaled-up to 1:32nd from a russian book "MiG 32 ML P MLD" by S. Burdin, published in Minsk, 1994, Pages 21- 28. Also of great help were "MiG-23 fighter variants MF,ML", bilingual Czech/English, from 4+ publications and "MiG-23/27 Flogger. Soviet Swing-Wing Fighter/Strike Arcraft", by Yefim Gordon and Keith Dexter, published by Aerofax.
The shape and length of the nose are wrong, as confirmed by placing the parts over 1:32 line drawings (the red lines represent the outline of the kit parts)
Profile nose too sharp, had to be replaced. I looked for an alternative and found that another Trumpeter kit. The point is that the nose has a wrong profile for aircraft came. The nose cone MiG 29!
On the left you can see the original MiG 23 con, shortened and MiG 29 a dry fit half the fuselage.
Pinocchio nose had set. This is how it looked:
Compare it to his new cone, the one modified from the MiG 29. It makes a huge difference
We also took the opportunity to further strengthen the area, or by adding styrene ...
