Very good alterations Millo, that is going to make a big difference to the finished model.
Mig-23 MLA 1/32 trumpeter (red-39)
The main gear is provided in two versions, both wrong, both too extended: for the ML and for the MF even worse, protrudes to the rear by one third , it cannot be retracted into the bay. The landing gear as is provided is simply unacceptable.
The main gear has two components that need to be modified so that the aircraft sits right. 5 (five) millimeters need to be removed from the axle beam assembly and the piston that actuates the retraction/extension of the gear should be lengthened by 4 millimeters. The gear legs were then improved.Comment
