How about using the hellblau & then shading the panels in a thin spray of white Polux? That would look good
I have been taking a look at the Steve colour....and looks more similar as my primer coat than the Hellblau I like your idea Patrick, my Stuka was painted on Hellblau and looks nice after the washes and others.
I reckon if you add a bit of grey or even white to your colour, which is supposed to be an equivalent for RLM 78, the tropical underside colour, you would be close to RLM 76 which is what you want.
Looks cool so far! One question though, is it better to paint parts of the model before putting it together or is it better to put it all together then painting it?
The both options are fine!
Sometimes is better to paint small pieces before and then add to the main set. Anyway, everyone has his preferences
Good luck with getting the right paint mate...The fw 190 I want to build is Grey in some pics and green in others. Terrifying.
Aaron this is a problem with late war aircraft as their was a transition to new colours and the allies were bombing the sh*t out of the aircraft factories causing logistical problems. If you let me know which one you are planning to do, I can at least give you an educated guess of what the colours would have been. In the absence of a good coloured image sometimes we can only go by other 'circumstantial' evidence, but a lot of new research has been done in the last few years.
Aaron this is a problem with late war aircraft as their was a transition to new colours and the allies were bombing the sh*t out of the aircraft factories causing logistical problems. If you let me know which one you are planning to do, I can at least give you an educated guess of what the colours would have been. In the absence of a good coloured image sometimes we can only go by other 'circumstantial' evidence, but a lot of new research has been done in the last few years.Cheers
Thank you Steve,I chose Prillers fw as my favourite paint option. Any help in tamiya or Vallejo colours would be appreciated.
I don't want to mess with your thread Polux, pls forgive my intrusion.
