Originally posted by \
Airfix 1/48 Folland Gnat
Originally posted by \Well, soldier on Dave, because we are all keen to see this wonderful Gnat in service soonComment
Originally posted by \Dang!!I bet that is not the first time any of us misread the instructions or stuck something the wrong way around or simlar!!
Progressive resistance, bub!!Comment
Well Dave glad to see your back on track after your minor mistake with the cockpit being clued back to front and upside downLol I can put this back on my wish list now then.so come on then on with the build and some more pictures please......good luck with the rest of it and no more beer!!!!!!!
[ATTACH]97616.IPB[/ATTACH]
[ATTACH]97617.IPB[/ATTACH]
I've done some filling and sanding this evening.Ive filled the gap in the fuselage behind the nose gear bay with superglue gel.And I've filled in my cockup In the cockpit rear bulkhead.The fit of this kit looks bad.But I think it's just very precise with no leeway for clumsy fools like me!.
Attached FilesComment
Originally posted by \!.Good job I don't drink when I'm working on real aeroplanes!.
Looks OK to me Dave. I like a tussle every now and then. Good for the soul. Nice panel line markings.
LaurieComment
Do you think the gaps in the fuselage and rear wing join might be because you got that bulkhead back to front and it has just thrown out any tolerances in the parts?On the bench: Airfix 1/48 Sea King HC4, Revell 1/24 Trabant.
Just finished: Airfix 1/48 Stuka & Airfix 1/72 Sea King HC4.Comment
Originally posted by \Do you think the gaps in the fuselage and rear wing join might be because you got that bulkhead back to front and it has just thrown out any tolerances in the parts?Comment
I opened up my one to have a look after reading this Dave. It looks beautiful and the detail is very nicely done. I was doing a bit of dry fitting and it seems well engineered in my opinion but some of the tolerances are very tight, especially around the cockpit, nose wheel and intakes I think even a coat of paint could leave the builder with fit issues. I'm committing mine back to the stash for now. Good luck with the rest of the build buddy.Comment
I've had another filling and sanding session.Thats enough untill I see what it's like with a coat of primer on.Then I glued on the tailplanes,wing flaps,Ailerons and rudder.Infact, the rudder and ailerons are designed to be moveable.I then turned my attention back to the cockpit.As you can see in the photo,quite a bit has to be removed from the base of the ejection seats so that the canopy can be fitted in the closed position.Im grateful to Mike (Migrant) for informing me of this problem.Otherwise I would have just glued the seats in,then at a later stage found that the canopy wouldn't fit properly!.Last thing I did tonight was glue some lead in the nose.Dont think this one would be a tail sitter but I want to be sure it isn't.
[ATTACH]97723.IPB[/ATTACH]
[ATTACH]97724.IPB[/ATTACH]
[ATTACH]97725.IPB[/ATTACH]
[ATTACH]97726.IPB[/ATTACH]
[ATTACH]98129.IPB[/ATTACH]
Almost ready for primer now.The canopy is very thin and quite delicate.So I've glued it to the model with Gators Grip before masking it.when the glue has dried I will mask it then spray a coat of primer on.Attached FilesComment
Originally posted by \I wonder if Airfix actually build one of their new kits before putting them on sale to make sure they go together as intended?.Comment
Originally posted by \It does make you wonder when it's something as basic as the seats not fitting - surely that would have shown up in a test build? Despite that your Gnat is looking really good, and I'm actually looking forward to building mine now I've been forewarned of some of the issues.Comment
