1/48 Tamiya P-47D
    1/48 Tamiya P-47D
    Hello
    I have finally received the tamiya P-47! The fuselage has very nice details on it and I have decided to use the Eduard photo-etch and mask kits. The cockpit fits very well into the fuselage and there seems to be no gaps.
    [ATTACH]97873.IPB[/ATTACH]
    unfortunately, the kit comes with instructions for only one colour scheme
    [ATTACH]97874.IPB[/ATTACH]
    Very detailed cockpit
    [ATTACH]97869.IPB[/ATTACH]
    Pre-shading with flat black
    [ATTACH]97875.IPB[/ATTACH]
    Then a coat of interior green. The pre-shading seems to be working well
    [ATTACH]97872.IPB[/ATTACH]
    All of the parts laid out. I have not finished painting the side wall instruments yet.
    [ATTACH]97871.IPB[/ATTACH]
    Dry fitting into the fuselage, fits perfectly.
    See you next time
    [ATTACH]97870.IPB[/ATTACH]
    • 22770
    Looking good Ivan great start, I'm doing the Revell 1/48 P47 at the moment, it will be nice to see the differences between the two kits.
      Yes, I look forward to seeing your completed model and to compare the two.
        So far, the build is going very well. All parts fit together perfectly and there are some very nice details. In order for me to build the motor I need some alclad paints so I will order them and while they ship I will probably start building the numerous underslung attachments such as bombs and drop-tanks.
        [ATTACH]97920.IPB[/ATTACH]
        Final assembly of cockpit
        [ATTACH]97927.IPB[/ATTACH]
        Interior of fuselage
        [ATTACH]97926.IPB[/ATTACH]
        The two fuselage halves glued together
        [ATTACH]97925.IPB[/ATTACH]
        A barely noticeable gap appeared on the bottom that required some filler
        [ATTACH]97924.IPB[/ATTACH]
        Tail wings attached
        [ATTACH]97922.IPB[/ATTACH]
        I decided to open the cooling flap
        [ATTACH]97921.IPB[/ATTACH]
        Started working on the engine but I need alclad aluminium paints to finish it
        See you next time
        [ATTACH]97923.IPB[/ATTACH]
          • 18266
          Thats coming along nicely.
            Coming along nicely indeed.
            scott
              Looking good Scott
              • flyjoe180
                • Jan 2012
                • 12400
                • Joe
                • Earth
                Nice work, that's looking good so far
                  • 22770
                  Looking good Ivan
                    Oooh! P47 Razorback…now that's a handsome bird! Looking good so far...
                      Looking really good so far Ivan.
                        So far going well, assembled and glued on the wings. They were a bit hard to get into the right position but in the end it worked.
                        [ATTACH]98026.IPB[/ATTACH]
                        The wings consisted of several parts that fit together perfectly
                        [ATTACH]98031.IPB[/ATTACH]
                        The Eduard masks worked perfectly
                        [ATTACH]98039.IPB[/ATTACH]
                        The masks were pre-cut so it did not take too long to apply them
                        [ATTACH]98042.IPB[/ATTACH]
                        I decided to put the flaps in the up position
                        [ATTACH]98041.IPB[/ATTACH]
                        To get the interior colour of the cockpit, I painted the clear parts interior green
                        [ATTACH]98040.IPB[/ATTACH]
                        Next, a coat of OD green mixed with some tan
                        See you next time
                        [ATTACH]98036.IPB[/ATTACH]
                        [ATTACH]98043.IPB[/ATTACH]
                        • colin m
                          • 8741
                          • Colin
                          • Stafford, UK
                          Looking nice. Great to get to the primer stage isn't it ?
                            Looking good great to start getting paint on.
                            • takeslousyphotos
                              • Apr 2013
                              • 3900
                              There's some superb detailing waiting under that masking....... I'll look forward to seeing it finished..........
                              Peter
