Great looking Thunderbolt so far. Those Eduard masks look good.
1/48 Tamiya P-47D
Finished painting some parts red and pre-shaded the underside of the fuselage and wings so that I can apply tamiya XF-19 sky grey later on.
I also airbrushed Aqua gloss on the dark green top, and for some reason it turned from a very smooth surface to a rough one. Why is this happening? Isn't a gloss coat meant to even and smoothen things out?
[ATTACH]98367.IPB[/ATTACH]
Not much pre-shading needed
[ATTACH]98368.IPB[/ATTACH]
At first I tried to airbrush red directly onto the green but the green would show through so I painted it white and then red and it worked
[ATTACH]98366.IPB[/ATTACH]
I finally got some alclad aluminium paint but it says I need a special airbrush cleaner. Would a normal cleaner work?
see you next time
I finished the engine and masked off the red tail today. The engine was very easy to assemble, was made of only three parts and it had some great details.
[ATTACH]98562.IPB[/ATTACH]
Took forever to mask because of the two little protruding rudder holders that had to be painted olive drab
[ATTACH]98564.IPB[/ATTACH]
I painted the pistons titan silver and the gearbox metallic grey
[ATTACH]98563.IPB[/ATTACH]
After the paint, I airbrushed a clear gloss coat and added a dark brown wash
[ATTACH]98561.IPB[/ATTACH]
Unfortunately, most of the engine detail will not be visible once the cowling is put into place.
See you next time
[ATTACH]98565.IPB[/ATTACH]
Finished the front part of the aircraft and glued it on. It fit perfectly and no filler was needed. I then pained it all olive drab.
[ATTACH]98668.IPB[/ATTACH]
I decided to put the cowlings in the closed position
[ATTACH]98667.IPB[/ATTACH]
No gaps
[ATTACH]98665.IPB[/ATTACH]
Painted with a coat of olive drab
See you next time
[ATTACH]98666.IPB[/ATTACH]
I got myself some alclad thinner so I used alclad dull aluminium to paint the wheel hubs and the land gear supports. I also painted the underside in light grey.
[ATTACH]99029.IPB[/ATTACH]
masked off and ready to be painted light grey
[ATTACH]99033.IPB[/ATTACH]
The landing gear turned out nicely I think
[ATTACH]99032.IPB[/ATTACH]
First coat of light grey
[ATTACH]99030.IPB[/ATTACH]
Test fitting the landing gears
See you next time
[ATTACH]99031.IPB[/ATTACH]
Finished paining the underside in grey but when I removed the masking tape, I found that there were stripes left from it so I painted over with a thin coat of olive drab.
[ATTACH]99177.IPB[/ATTACH]
I decided to paint the wheel wells with a brush rather than an airbrush.
[ATTACH]99178.IPB[/ATTACH]
Some touching up needed on the gloss red needed
