(IBG) PZL 42 - Polish Light Bomber - 1:72
  • pjgtech
    • Dec 2023
    • 834
    • Peter
    • Swale Kent UK
    #16
    Put three coats on the underside yesterday and it looks ok, not bad at all.
    So today I am painting the top side, will probably be another three coats, each separated by a few hours.
    Paint blurb says can be repainted after one hour, but I tend to leave it for at least 2 to 3 hours between coats, seems to work ok for me.
    Onwards..... 8-)
      • 15704
      Coming on well. You're always going to need a few coat for light over black.
      • pjgtech
        pjgtech commented
        Editing a comment
        Yep, actually I think it was four coats on the underside not three, as the first two coats tend to be a bit patchy, the third looks ok, and the 4th gives a good final coat, so will be four coats on the topside too. 8-)
    • Richard48
      • 1897
      • Richard
      • Clacton on Sea
      #18
      Looking great.A real different looking aircraft.Think the Poles and French fielded some off the wall planes in ww2.
      • pjgtech
        • Dec 2023
        • 834
        • Peter
        • Swale Kent UK
        #19
        Todays update:
        Touched up and tidied up few bits of paintwork...
Name:	pzl 42 pol litebomb 11jan25 (1).jpg
Name:	pzl 42 pol litebomb 11jan25 (2).jpg
        Masked up with tape and painted the prop cowl, a sort of dark rust colour, also painted two side exhausts.
        Also painted white sections to the rear tail fins.
        Glued canopy onto fuselage.
Name:	pzl 42 pol litebomb 11jan25 (4).jpg
Name:	pzl 42 pol litebomb 11jan25 (3).jpg
        Prop installed.
        Now just need to let paint dry, remove masking tape from prop cowl, then think about a varnish coat before applying decals.
        Bit worried about the decals, as the cockpit instrument decals and the canopy instrument panel decals both started to split and crumble during applying! So will need to be very careful with the external decals on the wings, etc.
        8-)
        • PaulTRose
          • Jun 2013
          • 6466
          • Tattooine
          #20
          If the decals are breaking up try coating the sheet in a thin layer of humbrol clear.....and when you cut them out trim as close as you can.....should hold them together long enough to get them on
          Per Ardua
          • pjgtech
            pjgtech commented
            Editing a comment
            Cheers for the tip, Have not got any humbrol clear, would any clear varnish do, eg: Tamiya?
        • PaulTRose
          • Jun 2013
          • 6466
          • Tattooine
          #21
          Not sure....ive done it before with humbrol acylic varnish rattle can
          I said Humbrol clear cos i always put a coat on where the decals going so it slides and sits better with the microsol......then i give a coat over the top when its dry.......then the decal wont silver when the final coat of varnish goes on
          its an old habit.......in the old days everyone used kleer floor varnish before it was changed.....humbrol clear is alledgedly the same stuff......hobbycraft sells it
          Per Ardua
          • pjgtech
            • Dec 2023
            • 834
            • Peter
            • Swale Kent UK
            #22
            Nuther update.
            Fully built and painted.
            Stupidly used a bit of CA glue on the canopy and its fogged up a bit, [sigh.......]
            Glossed, then put decals on. They went on ok, but looked like they would break up at any moment!
            Put some micro sol on and they seem to have set ok.
            Put a wash on. Still a bit wet.
            Last thing to do will be a matt varnish coat to knock it back a bit.
            Pics...
Name:	PZL 42 ol Lite Bomb 14jan25 (3).jpg
Name:	PZL 42 ol Lite Bomb 14jan25 (2).jpg
Name:	PZL 42 ol Lite Bomb 14jan25 (4).jpg
            • flyjoe180
              • Jan 2012
              • 12407
              • Joe
              • Earth
              #23
              Looks good Peter. Remember to mask the clear parts before you apply your matt varnish.
              • pjgtech
                • Dec 2023
                • 834
                • Peter
                • Swale Kent UK
                #24
                Final post on this one (and pics).
                Not the tidiest of finishes TBH, I rushed it a little bit, and not happy with the weathering, the panel line wash did not really show up the lines and my attempt at making the exhaust dirt/oil "plume" along the fuselage and wing was a tad overdone, but.....
                This was my first plane since I was about 12, so I used it as a "learning" experience, and I have deffo learned a few things.
                So hopefully my next plane will be better. I have a couple more, cheap, auction buys that were planes and will practice on those ones, before I attempt my very nice Mosquito and/or Heinkel ju88 builds.
                Final pics for this one after the final matt varnish coat.
Name:	PZL 42 Pol Lite Bomb 15jan25  (3).jpg
Name:	PZL 42 Pol Lite Bomb 15jan25  (1).jpg
Name:	PZL 42 Pol Lite Bomb 15jan25  (2).jpg
Name:	PZL 42 Pol Lite Bomb 15jan25  (7).jpg
Name:	PZL 42 Pol Lite Bomb 15jan25  (4).jpg
Name:	PZL 42 Pol Lite Bomb 15jan25  (9).jpg
                • Valeron
                  • Jan 2022
                  • 942
                  • Mike
                  • St Albans
                  #25
                  Nice looking finish. Onwards and upwards.
                  • Steven000
                    • Aug 2018
                    • 2828
                    • Steven
                    • Belgium
                    #26
                    Looking good Peter, interesting plane
                      • 15704
                      Nicely done. You're rattling through these builds. You've enjoyed it, learned a lot and got a result you're nopleased with. Perfect.
                        Jim R commented
                        Editing a comment
                        Last sentence should read ...
                        .... and got a result you're now pleased with.
                    • scottie3158
                      • 14202
                      • Holbeach
                      #28
                      Great result mate.
                      • colin m
                        • 8755
                        • Colin
                        • Stafford, UK
                        #29
                        Your first aircraft model since you were 12, well you should be really happy with that. You've tried many technique's all in one build. Great stuff.
                        • PaulTRose
                          • Jun 2013
                          • 6466
                          • Tattooine
                          #30
                          What an interesting looking aircraft.....i like that....well done
                          Quick tip on using ca on clear bits.......its not the glue that causes the fogging but the fumes.....so add just tiny amounts of glue then leave for a minute or 2 to let the fumes dissapate then stick the bits together...theres also a good trick with humbrol clear if you want to know some time
                          Per Ardua
                          • pjgtech
                            pjgtech commented
                            Editing a comment
                            go on..... 8-)
