Italari 1/32 Panavia Tornado GR1
  • BarryW
    • Jul 2011
    • 6010
    #46
    Well I have been spraying primer and now this lady is in her sexy black undies...
    i have been getting organised for my first painting round, a dozen different colour needed.
    Once this round is done i will put to one side the parts that just need weathering. Then any that need some hand painting and then those that need some masking for the second airbrushing round.
    • BarryW
      • Jul 2011
      • 6010
      #47
      Round 1 of airbrushing done. I will now sort everything into parts that are ready for weathering and those that need another airbrushed colour. I will then mask up for round 2 of airbrushing.
      Desert Pink above
      Bombs in bronze green and the undercarraige in a very light grey
      Some metallic areas on the fuselage. I prefer to mask over the metallic areas before painting the camo as I treat and weather them very differently to the camo. This is because i want to retain that metallic look.
      • BarryW
        • Jul 2011
        • 6010
        #48
        Round 2 airbrushing done, getting masked and ready for round 3.
        • BarryW
          • Jul 2011
          • 6010
          #49
          Round three - the desert pink but before that Dark Sea Grey around the inner swing wing with the wings spread.
          Then with the wings swept, the desert pink
          Nice smooth finish as usual with MRP. Nose cone tomorrow and a few other odds and ends before removing masking.
            • 15669
            Looking good Barry. I hope all's well when you remove the masking.
            • BarryW
              • Jul 2011
              • 6010
              #51
              Next spraying phase done, 5 colours in all. All masked and ready
              Spraying all done. Some minor touching up to do, just left the masks over the transparencies and most metalised areas. I don't want any varnish on most of the metal areas.
              Detail spraying done
                • 15669
                Great result Barry. Masking went well.
                • BarryW
                  • Jul 2011
                  • 6010
                  #53
                  Touching up done and I decided to go ahead with decals before applying a semi-gloss coat.
                  Unfortunately the decals are a little over scale. Here is a page from the instructions, look at the fit of the tail decal.
                  Now look at the fit in practise. Make no mistake, this is exemplified by the tail, I made multiple adjustments and in the end this is where I got to
                  The sharks mouth is also a little too large, I just have to make the best of this.
                    • 15669
                    You've made a good job of adjusting the decal positions but really that's a bad c***-*p by Italeri.
                    • boatman
                      • Nov 2018
                      • 14451
                      • christopher
                      • NORFOLK UK
                      #55
                      Originally posted by Jim R
                      As always, Barry, your work is very neat and well organised. The detail certainly looks nice and sharp. I hope the aftermarket stuff comes soon.
                      yes Barry very well done IF i get this kit im gonna go to town lightin it up
                      chrisb
                      • scottie3158
                        • 14201
                        • Holbeach
                        #56
                        Those decals are really not good. But your doing a good job of getting them to fit.
                        • BarryW
                          • Jul 2011
                          • 6010
                          #57
                          the kit decals are actually very good. Itโ€™s the aftermarket decals that are the problem.
                            Jim R commented
                            Editing a comment
                            Sorry. I thought they were the kit decals. I'd forgotten you were using am decals.
                        • BarryW
                          • Jul 2011
                          • 6010
                          #58
                          In trying to fit the over large tail decal into the best possible position I was not happy with how it looked and, on reflection, I concluded that the one I did fit on the other side just did not look right at all. I then decided not to use those decals at all so this is how the fin looks.
                          So beware of the XtraDecal brand and avoid if possible.
                          • BarryW
                            • Jul 2011
                            • 6010
                            #59
                            Decals are on. I decided not to apply a panel line wash as the black basing, combined with the over sized panel lines have done the job. I also want this to be fairly lightly weathered as this was a celebratory scheme. I will spray the very distinctive exhaust stains on the fin though.
                            I therefore applied a semi-matt coat to seal and provide the finish I want. A couple of pics.
                            Click image for larger version  Name:	20250225_160425381_iOS.jpg Views:	0 Size:	415.2 KB ID:	1249751
                            Click image for larger version  Name:	20250225_160429879_iOS.jpg Views:	0 Size:	534.6 KB ID:	1249752
                            Tomorrow its time for the exhaust stains on the fin. Then some streaking and final fittings. I will remove the masking over the metal areas too.
                            • scottie3158
                              • 14201
                              • Holbeach
                              #60
                              looking great Barry
