Meng 1/48 Me 410
    Ca'nt wait to see some pics Patrick and its all you're fault I just moved the 2 in my stash to the top of the next to do!
      After much trials & tribulation (not to mention swearing!) I've got the fuselage together.
      Meng don't believe in guide pins etc, and the ' snakehead ' shape at the forward end means using clamps in ways they weren't designed for!
      Also, because so much strength is needed where the clear part of the nose joins, I had to use CA cement, so fingers crossed it hasn't fogged up.
      I managed to break off the canopy bracing
      [ATTACH]102216.IPB[/ATTACH]
      [ATTACH]102217.IPB[/ATTACH]
      Wings are also well on their way to being done, just a few bits needed here.
      You do get 2 nicely detailed engines, but mine won't be on show, so they're just there to have something to hold the exhaust stacks & props.
      [ATTACH]102218.IPB[/ATTACH]
      [ATTACH]102219.IPB[/ATTACH]
      Finally the 5cm BK5 cannon pod.
      [ATTACH]102220.IPB[/ATTACH]
      Thanks for looking
      Patrick
        Looking great Patrick! Just a fyi , use foam safe Ca it wo'nt fog clear parts. Eagerly awaiting the next update!
          That office is looking very good, shall be watching this one.
          • Dave W
            • Jan 2011
            • 4713
            #20
            Looking good Patrick.I keep meaning to buy one of these.
              This is coming along very nicely indeed.
              scott
                Cheers Dave, it's in Hannants at 1/3 off, but John did me a special deal
                Although it's a nice kit, not everything matches the hype I've read & had I paid the RRP, I'd be feeling a bit disappointed.
                • Snowman
                  • Oct 2014
                  • 2098
                  #23
                  NICE!!
                  looks similar to the Hs 129 Panzerknacker... [ATTACH]102240.IPB[/ATTACH]
                  • flyjoe180
                    • Jan 2012
                    • 12400
                    • Joe
                    • Earth
                    #24
                    Nice start Patrick.
                      NICE!!
                      looks similar to the Hs 129 Panzerknacker... [ATTACH]112323[/ATTACH]
                      The Germans did like putting enormous guns on their planes!
                        You got a steady hand for painting. The cockpit is perfect. Nice work so far.
