This was a Christmas present, and I had high hopes for it - new mould, etc.
However, when you open the box, you are greeted with crisply moulded sprues in shiny white plastic. WHITE? This must be the worst possible colour to use - I struggle to make out any detail.
Even worse, when bits are fitted, there is no shadow or contrast on the seams, so you have to rely on fingernail feel to judge if the joins are smooth.
Having said that, it all went together well enough, apart from the engine cowl. It's an over-complex four piece construction, that needs filing to fit. The radiator flaps are a separate ring - open or closed, the main cowl is in two halves with a nose piece to fit on the end. I should have assembled the whole thing separately, but I fitted the pieces to the kit in stages.
Again, the colour of the plastic made it hard to judge the fit, and it's only now I've given it a coat of primer I can see how bad it looks.
I know a better modeller than me would have made a much better job, but I'm tempted to give up on this. I can't see how I can retrieve it with filling and filing.
I should have got the Academy version.
[ATTACH]107955.IPB[/ATTACH]
[ATTACH]107956.IPB[/ATTACH]
[ATTACH]107957.IPB[/ATTACH]
[ATTACH]107958.IPB[/ATTACH]
[ATTACH]107959.IPB[/ATTACH]
[ATTACH]107960.IPB[/ATTACH]
