You just may its not looking too far off now i bet your pleased with the hard work put in i know i would be
N1K2-J build
Kawanishi N1K2-J Shidenkai (George) (Hasegawa) - Scale Models Gallery
fantastic aircraft to build .... japanese WW2 aircraft have this very brutish attractiveness to them I think ...... they look great when finished.. looking foward to see'ing yours once done
rgds
lindseyComment
Thanks Lindsey and Tony. George is currently under a dust cover having had several coats of Klear. Next up: decals and weathering! : )Comment
Thank you, Lindsey! : ) Vallejo masking fluid helped me with the chipping.
I must get on and do some more with this build.Comment
That's right, Lindsey.
Natural metal finish first, and then I used a cocktail stick to apply the masking fluid. After the top coat, just gently rub the masking fluid off with your finger.
The only problem I encountered was that I pre-shaded my panel lines too thick. This mean some black also showed through with the silver beneath my green - the touching up brush came out at this point.Comment
Alex do'nt feel alone with the panel lines showing thru ,did the same on my Zero thank goodness for touch up brushes!Comment
Okay, I'm on the home run with this build now. I just have a few small details such as undercarriage, cannons and radio mast left to do.
.[ATTACH]35205.vB[/ATTACH]
[ATTACH]35206.vB[/ATTACH]
[ATTACH]35207.vB[/ATTACH]
[ATTACH]35208.vB[/ATTACH]
The flaps are just loosely placed on the model for the sake of weathering. Notice the headrest - this was actually made from wood in the real thing. If I did another of this type I'd try using some balsa instead.
Next photos should be the finished build
[ATTACH]39669.IPB[/ATTACH]
[ATTACH]39670.IPB[/ATTACH]
[ATTACH]39671.IPB[/ATTACH]
[ATTACH]39672.IPB[/ATTACH]
