Eduard spitfire mk IXc late version
  • PhilJ
    • May 2015
    • 1145
    Hi all, I'm new to the forum and haven't modelled since I was a kid, starting off with this spitfire that seems to be going together rather nice. Have added some thin copper wire in the cockpit for a bit more interest. I will keep it updated as much as possible, any comments would be very welcome. Have a great weekend.
    [ATTACH]109308.IPB[/ATTACH]
    [ATTACH]109309.IPB[/ATTACH]
    [ATTACH]109310.IPB[/ATTACH]
    [ATTACH]109311.IPB[/ATTACH]
    [ATTACH]109312.IPB[/ATTACH]
    Looks good so far, welcome to the forum! You must be in Australia though judging by the upside down pictures. Although I'm being smart, I have no advice on how to fix that!
    Keep up the good work
    • PhilJ
      • May 2015
      • 1145
      Yeah, not great with tech. Thanks for the comment Dougie I'll take a closer look when putting on the next pics, cheers
        Welcome to the forum Phil
        Yep! This cockpit is coming along very nice.
        I never finished it, but some time ago I started on of this, and is an excellent kit!
        Polux
          Nice job mate. NIce pit' looking forward to more pics. Btw, using Mr hobby buffable paint mettalics can be very useful for creating depth, especially on oxygen bottles. However, if you can't get some, it can be got for a good price from a mail order warehaouse in Australia.
          • PhilJ
            • May 2015
            • 1145
            That's interesting john, to be honest I'm not 100% happy with some of the interior due to lack of materials. A couple of weeks ago I basically found a compressor that the missus had for spray tanning and a bottle feed Iwata, I sold the Iwata purchased a harder and Steinbeck and about £100 worth of gear off amazon and have just started getting back in to modelling for the first time since I was a kid. I need to beef up a bit more on materials over the next couple of months so any pointers will be much appreciated. I have heard very good things about alclad metallics which I was looking to get so what's best for through the airbrush and what's best for brushing? I'm currently using Vallejo primer and model air which is working out nice.
              I use alclads as well. It is an excellent piece of kit. A few bottles of alclads wont harm you. However, I don't use them extensively as I do mainly WW 2 Aircraft in 1:48 and 1/32, especially Luftwaffe types. Alclads are good for NMF finishes. However, the Eduard IXc you have has a scheme of an NMF finish. The Mr hobby buffables are great. They fine with being brush painted, then after 10-20 miutes, they are buffed up, with the grime staying in the recesses and the metallic showing up on the detail. This is particularly effective for plastic grilles and undercarriage legs. Also, oxygen bottles, unless they were painted, benefit from this effect
                In terms of primer, I use the Mr Hobby surfacer 1000. This is a real hit for the money as it can be used as a micro filler and a primer when it is thinned with cellulose/lacquer. It is really tough, and you should find no problems with it spraying out of your AB. I used to use an Iwata Neo, until I bought an Iwata Eclipse HP-CS, then a high performance. They all have Teflon seals, and therefore, the lacquer does not effect it
                  • 22770
                  Great start Phil
                  • PhilJ
                    • May 2015
                    • 1145
                    [ATTACH]109355.IPB[/ATTACH]
                    [ATTACH]109356.IPB[/ATTACH]
                    Primer on... Can't work out why all the photos are upside down its driving me mad!
                    • eddiesolo
                      • Jul 2013
                      • 11193
                      [ATTACH]120097[/ATTACH] [ATTACH]120098[/ATTACH] Primer on... Can't work out why all the photos are upside down its driving me mad!
                      Looking good, despite the defying gravity shots...
                      • PhilJ
                        • May 2015
                        • 1145
                        I have seen some shots of this one in the NMF finish and it does look nice, I haven't got the bottle for attempting that yet as I've only been using a airbrush for a few days, next time maybe. I'll look into those Mr hobby metallics john did you say you can get them in a pack?
                        • eddiesolo
                          • Jul 2013
                          • 11193
                          If you are referring to the pens, then yes you can get them in a pack Phil.
                          Si
                          • PhilJ
                            • May 2015
                            • 1145
                            Anyone know if I can give the Vallejo primer a light rum down once it's gone off? It's had one dust coat and two light coats... Also how Lind shall I wait if I can rub down gently 12 hrs? Or more?
                            • PhilJ
                              • May 2015
                              • 1145
                              Cheers Si
