Ade's F-4F Phantom II WTD 61 "Flight Test"
  • Robert1968
    • Mar 2015
    • 3596
    #16
    The remove before flight tags give realism
    The white metal undercarriage ( is it really worth it
    Regards
    Robert
      This is going to be another masterpiece! I will watch this build with wide open eyes!
        That cockpit looks real nice, I remember buying a phantom a few years back in the same scale and from Revell and the fit was terrible.
        scott
        • Snowman
          • Oct 2014
          • 2098
          #19
          That is a nice looking "office"!!
          • takeslousyphotos
            • Apr 2013
            • 3900
            #20
            I have a set of PE "Remove Before Flight" tags I will never use if you want them Adrian, I believe they are 1/35 scale but at that sive I guess it won't make a spit of a difference. If you want them PM me your address and I'll put them in an envelope and post them off to you.
            • Adrian "Marvel" Reynolds
              • Apr 2012
              • 3008
              #21
              Wow very kind of you Peter, PM on its way
              Adrian
                • Apr 2012
                • 3008
                #22
                Couple of nice bright pictures
                Seems a bit alien to me to be spraying an aircraft in anything other than drab colours
                I'll post more pictures as soon as the masking comes off.
                [ATTACH]110734.IPB[/ATTACH]
                [ATTACH]110735.IPB[/ATTACH]
                [ATTACH]110736.IPB[/ATTACH]
                Comments welcomed as always.
                Adrian
                  That's been Tango'd! Well, a bit has
                  It looks really nice Adrian
                    • Apr 2012
                    • 3008
                    #24
                    Quick update and a little mock up of how things are looking now
                    [ATTACH]110795.IPB[/ATTACH]
                    Adrian
                      Its almost Dennis the menace! good work mate, very nice paint work so far
                      • flyjoe180
                        • Jan 2012
                        • 12418
                        • Joe
                        • Earth
                        #26
                        I like it! So satisfying to see something other than camouflage going onto a military jet.
                          • Apr 2012
                          • 3008
                          #27
                          Well, I followed the painting instructions and then went to apply the decals,
                          I had around 8 decals all nicely on when I noticed the next one wold leave a 3mm gap.
                          This means the bright orange will show a strip where it should be black,
                          I've thought about masking and painting the black but think it will show with it been a gloss black.
                          I've emailed Revell in hopes that I can get some more decals, if I can I will remove the ones I've done already and respray the paint but leaving a wider line.
                          Here's a quick pic,, basically the black should be full at the leading edge.
                          [ATTACH]111662.IPB[/ATTACH]
                          Right now it's boxed up and put away till I get my mojo back
                          Any advice, comments more than welcome.
                          Adrian
                          • flyjoe180
                            • Jan 2012
                            • 12418
                            • Joe
                            • Earth
                            #28
                            I'd just paint it Adrian, if you applied a gloss coat over the model it should blend in.
                            • takeslousyphotos
                              • Apr 2013
                              • 3900
                              #29
                              I'd go with that as well........
                                • Apr 2012
                                • 3008
                                #30
                                I've considered this, but if you look close at the rear of the tail and the rear of the wing, I should have set the decal 3mm backward, now I'd have to also mask and paint the checks to match up.
                                What I'm saying is I buggered it up, should have started with the rear tail decal and worked forward.
                                Adrian
