I think you have mastered this beast now Adrian, it's looking good.
Ade's Good Evening Da Nang F-4C Phantom II
Originally posted by \all the fw 190s by eduard are dogs. If you think the dora is bad-the A series is even more diabolical!
They build into excllent replicas though, and are the most accurate on the market. (well, off the market now, they aren't being produced any more)
AdrianComment
Originally posted by \Oh did you have to say that I have the Fw 190D JV44 Combo set in my stash and was looking forward to building two aircraft side by side, but if I'm going to have double the problems I think I'll pass
Adrian
I encourage you to build at least one dora. Although hard to build, they make excellent replicas and they are the most accurate doras around
JohnComment
Quick update and also need some advice
So used the new Stynylrez white primer on my build and I'm really happy with it, shame its going to be hidden under masses of pre shading
I pretty happy with the way the side pod came out, it took a lot of work but I think its paid off,
[ATTACH]115646.IPB[/ATTACH]
[ATTACH]115647.IPB[/ATTACH]
Now for the question, looking at the instruction for the resin seat it shows some .2mm wire added, see the attached picture, my question is what colour would this wire be?
[ATTACH]115648.IPB[/ATTACH]
[ATTACH]115649.IPB[/ATTACH]
Thanks all in advance
Adrian
Will this help? I took these photos of the RAF Phanton at Hendon.
[ATTACH]115650.IPB[/ATTACH]
[ATTACH]115652.IPB[/ATTACH]
[ATTACH]115653.IPB[/ATTACH]
[ATTACH]115651.IPB[/ATTACH]
Just finished: Airfix 1/48 Stuka & Airfix 1/72 Sea King HC4.Comment
It's this section here:
: [ATTACH]115654.IPB[/ATTACH]
Which when completed looks like:
[ATTACH]115655.IPB[/ATTACH]
[ATTACH]115656.IPB[/ATTACH]
It looks to be the same colour as the seat plating.
Apparently it's a guillotine hose. Whatever that meanshttp://www.ejectionsite.com/f4seat.htm
[ATTACH]115657.IPB[/ATTACH]
[ATTACH]115658.IPB[/ATTACH]
Attached FilesComment
Originally posted by \Apparently it's a guillotine hose. Whatever that meanshttp://www.ejectionsite.com/f4seat.htm
[ATTACH]126953[/ATTACH]
[ATTACH]126954[/ATTACH]
Rescue winches also have a cartridge fired guillotine to cut the winch cable and jettison it if it becomes snagged. It is essentially a blade that cuts a cable and a small explosive charge provides the inertia.On the bench: Airfix 1/48 Sea King HC4, Revell 1/24 Trabant.
[ATTACH]126954[/ATTACH]Comment
Weapon load out done for my Phantom, and just incase any rivet counter passes by when its on display I have checked and double checked they are correct for that theatre !!
[ATTACH]115957.IPB[/ATTACH]
Adrian
Originally posted by \Weapon load out done for my Phantom, and just incase any rivet counter passes by when its on display I have checked and double checked they are correct for that theatre !!
[ATTACH]127272[/ATTACH]
AdrianComment
