Ferrocious Frankie Build
    Tamiya P51-D Mustang
    1:48 scale
    Eduard Photo Etch for cockpit details.
    Macro shots taken in the studio with a Canon EOS M3 mirrorless compact camera to which a Canon TS-E 90mm lens and 20mm extension tube was attached via an adapter. Lit with three Canon 600ex-rt flash guns mounted inside a large softbox 600. exposure was 1/60th sec. @ f16 iso 100.
    The cockpit area is just over 2cm in length.
    My wife has always loved the P51, and Ferrocious Frankie in particular. So to keep in her good books, this one is for her.
    Scratches on the seat where the pilot clambers in and out were carefully markes with a sharp silver pencil. The wood effect flooring was grained and weathers with tamiya weathering sets. Flory models wash was applied to give relief. Photo etch was glued with medium superglue and some with gator glue.
    Here is one of my photos of the real Ferrocious Frankie, on which my model will be based.
    [ATTACH]115729.IPB[/ATTACH]
    And on the the images of the cockpit assembly.
    [ATTACH]115730.IPB[/ATTACH]
    [ATTACH]115731.IPB[/ATTACH]
    [ATTACH]115732.IPB[/ATTACH]
    [ATTACH]115733.IPB[/ATTACH]
    [ATTACH]115734.IPB[/ATTACH]
    [ATTACH]115735.IPB[/ATTACH]
    [ATTACH]115736.IPB[/ATTACH]
    That is really great stuff Graham. Thanks for sharing your stuff.
    Your meticulous dedication to detail is fascinating.
    Look forward to the next section.
      Excellent work on the cockpit Graham.
      I personally like the seat, it has a very nice colour and a credible subtle weathering.
      • takeslousyphotos
        • Apr 2013
        • 3900
        Superbly done Graham,,,,,,, Both the cockpit detail and the photographs.
        • Adrian "Marvel" Reynolds
          • Apr 2012
          • 3008
          Fantastic pictures and great detail, thanks for the information on the camera setup as well
          Adrian
            Graham where did you get those seatbelts they are superb ?
              Hi Laurie
              The seat belts are part of the Eduard photo etch cockpit set.
                Hi Laurie
                At 1/48 Graham they are the best I have seen.
                • flyjoe180
                  • Jan 2012
                  • 12390
                  • Joe
                  • Earth
                  Superb work so far Graham.
                    I received a spray booth for my birthday, and this was the first time I used it. The difference was notable. Apart from the obvious benefits to the air quality in the man cave and my lungs, the finish on the models was much improved without the oversparay floating around everywhere.
                    The filling the small imperfections and seams with Perfect Plastic putty and Vallejo Plastic Putty was completed and let to cure overnight.The seams were then sanded down and polished to leave a perfectly scratch free finish. The Vallejo putty was used along the wing root joins and levelled down using Isopropanol on cotton buds. This left a pefectly filled join with no areas to sand and smooth.
                    I then cleaned the thoroughly to remove any dust from the sanding, using airbrush cleaner on cotton buds for those awkward little places and wiped over with an airbrush cleaner moistened flock free paper towel.
                    Once dried, it was then placed on flock free paper in the spray booth and given a smooth coat of Vallejo 74601 grey surface primer, airbrushed with a 0.5 needle on the airbrush at 28psi. The spray booth worked a treat, keeping stray dust and overspray off of the model.
                    [ATTACH]116983.IPB[/ATTACH]
                    [ATTACH]116984.IPB[/ATTACH]
                    [ATTACH]116981.IPB[/ATTACH]
                    [ATTACH]116982.IPB[/ATTACH]
                      • 22770
                      Just seen this one Graham. Great work on the office, very nice. And looking good in the undercoat
                        Has this model been finished
                          Hi Roger
                          I'm still at it!
                          It has been painted once, but I wasn't entirely happy with it, so it was stripped down and I'm about 3/4 of the way through again. The main upper colours were airbrushed first, then the invasion stripes and the yellow nose. The aluminium has been done and sealed. I am looking forward to finishing it off, as I think it is coming together well. A new job is currently taking up all of my time, but it should ease up in the new year.
                            Hi Roger
                            I'm still at it!
                            I hate it when work gets in the way
