Academy 1/72 T-6
    Academy 1/72 T-6
    I started this little 1/71 T-6 from academy
    Quite nice, detail[ATTACH]116294.IPB[/ATTACH]
    s OK for this scale, however the trimtab pushrod on the right elevator should be on the bottom not the top.
    Aftermarket SAAF decals on the way to represent a plane at the field I work.
    Theuns
  • takeslousyphotos
    • Apr 2013
    • 3900
    Looks good Theuns...... I do admire people who work in the small scales.......... As for the Elevator trim tab, can't you remove it and "scratch" something for the underside ?
      I will just cut it off and glue to the bottom.
      Strange they would get it wrong, it's not like T-6 is a rare plane.
      On the full size T-6 we have only one elevator that can be swoped either side.
      Theuns
        • 22770
        Very nice so far Theuns
          I will leave the canopy on this one closed, pity it can not be posed open as the detail is quite nice.
          Theuns[ATTACH]117021.IPB[/ATTACH]
            • 22770
            That's a pity Theuns, but with that canopy at least you should be able to see inside
              Well, I still need to paint on the "inbetween" frame members on each canopy section, the one I am modling is a T6C and the kit is a t6G with less framing.
              It will look like this.
              Theuns[ATTACH]117097.IPB[/ATTACH]
                I decided to go with a different color for this one, I will do the SAAF one later
                This one is in the colors of a display team I work for now "Cell C"
                More color to go on.
                Theuns[ATTACH]118023.IPB[/ATTACH]
                  • 22770
                  Nice work Theuns and a good change of schemes looking forward to seeing what it looks like
                    Nice work, keep the pics coming
                      After sanding down I repainted it, not perfect but I can touch up the small flaws.
                      Then decals go on.
                      Theuns[ATTACH]119412.IPB[/ATTACH]
                      • colin m
                        • 8741
                        • Colin
                        • Stafford, UK
                        Looks good, certainly a different scheme.
                          Decals went on OK....
                          I am modling # 2 of the 5 ship "Flying Lions" team because it is the plane I was the backseater in last week when we did the BoB memorial flypast :-)
                          [ATTACH]119884.IPB[/ATTACH]
                          [ATTACH]119885.IPB[/ATTACH]
                            Nice build often wondered can you here the crack of the prop tips going supersonic from inside
                              Very clearly yes , you can hear it especially when doing tight formo flying, the other guys are litelrally no more that 4-6' wingtip seperation.
                              Theuns
