Tamiya 1/48 Lancaster
  • Dave W
    • Jan 2011
    • 4713
    This is my next build .I bought the kit around 5 years ago.But I wanted to wait until I'd acquired some experience with weathering before I built it. I've got a few extras for it.The Mask set will make masking the turrets easier. And the brass gun barrels are a big improvement on the over sized plastic ones in the kit. This is an old kit not up to Tamiyas current high standards.But it's not that bad either.When I built one around 25 years ago, I remember the engine cowlings being a bad fit.Looks like Tamiya have up dated these parts as there are separate sprues with finely engraved cowling parts that weren't in the original kit.The decal sheet has been updated as well.Ive still got some from my first kit and the red on the roundels was way too bright.This ones much better.The kits been built on here a few times,so I haven't included any sprue shots.I will make a start this evening.[ATTACH]118344.IPB[/ATTACH]
    [ATTACH]118345.IPB[/ATTACH]
    [ATTACH]118346.IPB[/ATTACH]
    This will be an interesting one Dave
      I shall be watching this one Dave.
      • Dave W
        • Jan 2011
        • 4713
        Haven't seen you on here for a while Terry.What have you been up to?.
          I have dipped in and out when possible Dave. I have been busy with family things,jobs Swsbo wants doing and I started a new job. After 11 years of doing care work I needed a change.
          • rickoshea52
            • Dec 2011
            • 4076
            • Rick
            I thought I saw this in your workbench snap on another thread. Your thought process on weathering skills development is wise I think, that's why I haven't started my eduard Mig-21's yet.
            • stona
              • Jul 2008
              • 9889
              The cowling to wing fit is still not great. I had to cajole mine into fitting.
              My wings also had a raised line running the length of the wings which doesn't exist on the real thing. That too I sanded off, which was a right pain. I read somewhere that when Tamiya measured up a Lancaster back in the 70s it had tape applied to the wing for some reason and this is what they molded as a result. No idea if that's true or not .
              There is some issue with the rear turret. It might have been that the gun supports are backwards in the instructions but it's been a while and I'm not sure.
              I left the interior alone, but there's room for improvement.
              • Dave W
                • Jan 2011
                • 4713
                I will bear your comments in mind.Im aware of the raised lines but will probably leave them alone.There are also thick raised ribs on the ailerons which I will probably sand off.Apparently the vertical bracing struts by the navigators position are half inch too far forwards as well.Not sure if they can be seen through the canopy though.
                  subscribed, this is going to be a good watch! lots of good pics please haha
                    • 22770
                    Jumping in to watch this one if you don't mind Dave
                    • Adrian "Marvel" Reynolds
                      • Apr 2012
                      • 3008
                      Watching this one, built the same kit a couple of years ago so interested to see what you do with it
                      Adrian
                      • tr1ckey66
                        • Mar 2009
                        • 3592
                        Hi Dave
                        This promises to be a cracker. Seen a few excellent built examples (some on this forum) and I'm sure you set to join them. The after market stuff will make a big difference and the masks are sure to help with complex glazing.
                        Best of luck with the Lanc I'll be sure to stay tuned.
                        P
                          I'm pulling up a chair and joining this one
                          Cheers Andrew
                          • stona
                            • Jul 2008
                            • 9889
                            I left the interior as there really isn't much visible through the canopy. Obviously if you get close up with a torch you might see something, but you can't do that with mine as it's on a high shelf
                            • Dave W
                              • Jan 2011
                              • 4713
                              I've only bought a basic etched cockpit set and seat belts as I don't expect to be able to see much through the canopy. Eduard do a fair amount of after market stuff for this kit.You could spend a small fortune on it.
