Tamiya 1/48 Lancaster
    Coming along nicely. The brass barrels look the business, interested to see how much difference they make on the final build. Had considered them but at 1/72 it seemed unnecessary... but not sure I've done the right thing.
    • Dave W
      • Jan 2011
      • 4713
      #47
      I think the barrels and the mask set are a good investment.Not sure about the interior detail set though.But that's why I only buy the Eduard Zoom sets.They give you a few bits like the instrument panels for a very reasonable price.As you say ,probably not necessary in 1/72 as hard to see even in 1/48.
      • tr1ckey66
        • Mar 2009
        • 3592
        #48
        Excellent work Dave I love the Lancaster and I'm looking forward to seeing this finished. I know this is jumping the gun a bit but any thoughts on which particular aircraft you're going to finish it as?
        I will definitely buy the HK 1/32 Lanc it just has to be done.
        P
        • Dave W
          • Jan 2011
          • 4713
          #49
          Excellent work Dave I love the Lancaster and I'm looking forward to seeing this finished. I know this is jumping the gun bit but any thoughts on which particular aircraft you're going to finish it as?
          P
          Not sure yet.Probably one of the kit schemes.Although I've got left over decals from the last time I built this kit for Guy Gibsons 'Admiral Prune'.An aircraft he flew before he commanded 617 sqdn.
          • PhilJ
            • May 2015
            • 1145
            #50
            Looking good Dave, the Eduard bits are really good aren't they and I should imagine the masks are a must for some of the old bombers.
            Phil
            • Dave W
              • Jan 2011
              • 4713
              #51
              I've assembled and glued on the tailplanes.Ive filled the gaps at the fuselage join with perfect plastic putty.Its great for this job as it can be smeared into the join and the excess cleaned off with damp cotton buds.No sanding needed.The elevator trailing edges are quite thick and could do with thinning down.But I've just left them as they are.And I've glued the engine cowling halves together then glued them to the lower wings.[ATTACH]119456.IPB[/ATTACH]
              [ATTACH]119457.IPB[/ATTACH]
              • colin m
                • 8759
                • Colin
                • Stafford, UK
                #52
                Coming along nicely Dave. Pre cut masks, I'm all for them...
                • flyjoe180
                  • Jan 2012
                  • 12418
                  • Joe
                  • Earth
                  #53
                  Those gun barrels certainly make a big difference Dave, nice work.
                    Very nice Dave are you going to detail the bomb bay or do as standard
                    • Dave W
                      • Jan 2011
                      • 4713
                      #55
                      I'm going to do the bomb bay using only the kit supplied items. I might even close the bomb doors.I haven't decided yet.
                        Love the fun barrels they look much better than the kit ones
                          what a cracking build,i have only recently started kit making again,but there are many builds on here of a very high quality,this being one of them
                            • 22770
                            #58
                            Some great work since I last looked Dave and like the rest have said the gun barrels look tons better
                              Looking great Dave ,the gun barrels were an excellent call !
                              • Dave W
                                • Jan 2011
                                • 4713
                                #60
                                [ATTACH]120007.IPB[/ATTACH]
                                [ATTACH]120008.IPB[/ATTACH]
                                [ATTACH]120009.IPB[/ATTACH]
                                [ATTACH]120010.IPB[/ATTACH]
                                [ATTACH]120011.IPB[/ATTACH]
                                [ATTACH]120012.IPB[/ATTACH]
                                Tonight I've been putting the undercarriages together.They are quite complex ,with 13 parts each side not including the wheels.Ive taken my time with them attaching a few parts,Letting them dry and glueing on a few more.Tomorrow, I will glue the completed assemblies to the upper wing halves then paint them.
