Originally posted by \
Tamiya 1/48 Lancaster
[ATTACH]121993.IPB[/ATTACH]
I've started masking up for spraying the black areas.Attached FilesComment
Looking good Dave, that's a lot of masking you done there( hope it pays off. Looking very clean and tidy
Guy would be proud of you I'm sure
RobertComment
That's not very good news regarding the redundancies Dave, but as you say you're in a pretty good position with your qualifications. You may have to work away from home, but it's a good thing you have already rehearsed building in a hotel room
The Lancaster is looking great, nice to see the pre-shading working.Comment
Originally posted by \That's not very good news regarding the redundancies Dave, but as you say you're in a pretty good position with your qualifications. You may have to work away from home, but it's a good thing you have already rehearsed building in a hotel room
[ATTACH]122161.IPB[/ATTACH]
[ATTACH]122162.IPB[/ATTACH]
[ATTACH]122163.IPB[/ATTACH]
Masking completed.Two coats of Revell Anthracite enamel sprayed on.Masking removed.
[ATTACH]122515.IPB[/ATTACH]
I started putting the decals on tonight.My 20 year old nose art decal went on fine.But the 5 year old Tamiya sqdn codes and my replacement Xtradecal codes broke up into small pieces.One of the Xtradecal 100" wing roundels also broke up.So I will have to buy some more.Attached FilesComment
[ATTACH]122785.IPB[/ATTACH]
[ATTACH]122786.IPB[/ATTACH]
[ATTACH]122787.IPB[/ATTACH]
Still waiting for the decals I ordered to turn up.The Tamiya wing walk decals wouldn't go on without silvering.So I've removed them and painted the black lines on instead.
Originally posted by \Nice work Dave, how does painting the walkway lines compare to applying decals? Would you do it again? They can be a little fiddly can't they?
Was they brush painted in one hit?
PhilComment
i have just swapped one of these kits for my 1/24 stuka i'm getting the dam buster one but not quite sure if it's the older kit or the newer one i am going to collect all the photo etch for it and maybe some resin parts for it so i will be following your build log very closely.
i was thinking of converting it back to a normal bomber lanc though and not the dam busters one with resin kits and photo etch parts etc.
i will be asking lots and lots of questions as i have never built a plane this big before i will also be using the white metal undercarriage and resin wheel kits.Comment
is it worth adding some bright L.E.D lights to brighten up the inside so you can see the detail work that i am going to put inside the fuselage ?Comment
