1/32 beaufighter
    1/32 beaufighter
    Hi folks here is another thing with wings, the revell 1/32 beaufighter hope you like it all comments are most welcome.
    Scott[ATTACH]119579.IPB[/ATTACH]
    [ATTACH]119580.IPB[/ATTACH]
    [ATTACH]119581.IPB[/ATTACH]
    [ATTACH]119582.IPB[/ATTACH]
    • 22770
    Glad to see you've started this one Scott and a very nice start too.
    • peterairfix
      • Jul 2012
      • 11074
      A good start i have the same kit and i have had no end of probems with it so i wish you luck
        Have an issue with how the wing ends are fitted any advice would be welcome.
        Scott
          • 22770
          Scott
          Sorry can't help there Scott never built this one have you any pictures to look at to see if we can help
          • colin m
            • 8741
            • Colin
            • Stafford, UK
            She's a big old dear isn't she....
            • peterairfix
              • Jul 2012
              • 11074
              Scott
              I had the same, aparently the wings go on when you put the centre section together so i just cut off some of the locating parts so it will just slot in.
              And i got so fed up with mine i have abandond mine until i am in the mood for it
              • yak face
                • Jun 2009
                • 13840
                • Tony
                Nice start scott , its a big old beast isnt it? Its got its issues (fictional cockpit , shallow wheel wells , wrong shape rear canopy) but it makes into an impressively sized model and it looks like a beaufighter so its still a good old kit , i keep saying i might do another one but when i think of the work i did on the last one i change my mind!! If I recall correctly i fettled the locating slots for the outer wings and when glued used stretched sprue to create a raised panel line over the joint , cheers tony
                  The wings are this good, any suggestions on how to fix them.
                  Scott[ATTACH]119590.IPB[/ATTACH]
                  [ATTACH]119591.IPB[/ATTACH]
                  [ATTACH]119592.IPB[/ATTACH]
                  [ATTACH]119593.IPB[/ATTACH]
                    I was thinking about trying to sand down the undersides of the wing hopefully without misshaping them, then applying filler, what do you think?
                    Scott
                    • peterairfix
                      • Jul 2012
                      • 11074
                      Scott
                      Yep i think it looks like buckets of filler and hours of sanding
                        Hi all this is where ism now with my beaufighter, what do you think?
                        Scott[ATTACH]119776.IPB[/ATTACH]
                        [ATTACH]119777.IPB[/ATTACH]
                        [ATTACH]119778.IPB[/ATTACH]
                        [ATTACH]119779.IPB[/ATTACH]
                        [ATTACH]119780.IPB[/ATTACH]
                        [ATTACH]119781.IPB[/ATTACH]
                        • monica
                          • Oct 2013
                          • 15169
                          looks a lot better than it was,I do think your done a good job,
                          can see you need a bit f work with the panel lines,
                          as there raised,could you use wire ,by resecribing the line so the wire sits in
                          and then,just sand it to a bit of a point ?
                            Nice idea Monica, that way the wire isn't higher than the panel line, like the way you think.
                            Scott
                            • monica
                              • Oct 2013
                              • 15169
                              ta Scott glad to be of some help,
                              some times cannot think of a way without seeing it,if you know what I,mean,
