Something big and German-Bf110
  • stona
    • Jul 2008
    • 9889
    This is Scott's (Noble) fault!
    Having seen the progress on his Heinkel 111 I decided I had to do something big and German, as the title suggests. Since my 'stash' consists of just two kits (I'm a builder not a collector!) I only had one choice and this is it:
    [ATTACH]124130.IPB[/ATTACH]
    The other half of the stash is a Tamiya P-51, but that's for another day
    I haven't read a review or even opened this box yet. I'm hoping it will be a decent kit, it will be if their Bf 109 is anything to go by.
    I hope I can make something that looks better than the awful box art.
    More to come.
    I'm sure you will do it justice Steve, as always. The 110 is a cracking plane and it will be interesting to see this manufacturer's interpretation of it.
    • BarryW
      • Jul 2011
      • 6010
      Steve its a great kit and a real pleasurable build.
      I did another version of this kit but most of the parts will be the same.
      Some pointers - the instructions were awful on mine, totally inadequate not sure if they corrected them in later versions of the kit. I downloaded the instructions for the Eduard 1/48 Bf110 which were more use than the Dragon ones!!!
      There are also some good on-line reviews, a couple that itemise most of the problems with the instructions pointing out the correct kit part number, part positioning and part not mentioned in the instructions. So it is well worth doing some research. I had about four documents to guide my build in all not counting any additional research I did.
      If you want to fit the engine panels then you need to leave out the engines. Its easy enough but you will need to use plastic card to get good joins.
      Here is a link to my post
      • stona
        • Jul 2008
        • 9889
        Thanks Barry, very helpful.
        I'd forgotten about your build, very nice it was too. Looks like I need to do a bit of research on the kit before I start!
          Nice one Steve.
          I'm glad to see you building again
          Polux
            That is gonna be huge.
            Have fun with this and it should turn out great.
              That's a nice lookin kit steve and the work you do and the finishes you achieve....well I've got my popcorn and iam glad that its my fault.
              scott
                • 22770
                Nice one Steve going to watch this one as I've got the Eduard 1/48 version
                • stona
                  • Jul 2008
                  • 9889
                  I've had a quick look at the contents.
                  The box art and profiles in the kit are wrong as that aircraft had the extended 'boat tail'. I think I've found the bits to do this.
                  I haven't found the bits for the extra 75 litre oil tank that this aircraft carried under the fuselage so I'll either make something else or scratch build one. The large under wing fuel tanks, the 198 litre version, often with fins, isn't included either. I'm a bit worried now about what else will be wrong. I haven't even started to check the minor variations between the E and other variants (pitot, tail wheel, rudder trim tabs, windscreen armour and a host more).
                  • yak face
                    • Jun 2009
                    • 13836
                    • Tony
                    Nice choice steve , its going to be a big un! The box art is a bit cheapo isnt it !! Hopefully itll be a better build , Barrys certainly looked superb when it was done , cheers tony
                      The box art is seven shades of wrong perspective wise! I'm sure the contents are fine, but that's the shoddiest box art I've seen for a while! Far wing is bigger than the foreground wing, such an oddity, for most of the time, I am filled with joy at the skills of the model box illustrators
                        Really gonna follow this though...I have an Eduard 110 in my stash!
                        • Gern
                          • 9213
                          Of course you will Steve so I'm looking forward to this.
                          Mind you, it still won't be as big as an He111. Hint, hint!
                          • geegad
                            • Mar 2010
                            • 2329
                            thats going to be one big bugger looking forward to seeing you get under way
                            • monica
                              • Oct 2013
                              • 15169
                              will be in on this one Steve,should be an interesting build,
