Something big and German-Bf110
  • stona
    • Jul 2008
    • 9889
    #61
    I think it's a very nice kit, from a construction and engineering point of view. I'm not a rivet counter and I haven't measured the fuselage in case it might be 0.6mm too long, or short
    Close of play shows some remarkable progress given my normal glacial progress!
    I've had to stop as I have shortly to dress up like the bloody ship's monkey to go to some do with SWMBO
    I also have the HK Models Do 335 burning a hole through one of my shelves. It's providing an incentive to get on with this one as I really want to start it.
      • 22770
      #62
      Awesome work so far Steve
      • stona
        • Jul 2008
        • 9889
        #63
        I finally found something that needed a little fix. You could fit the tail plane without this piece of packing, but it's much more solid with it.
        Without it you the leading edge of the tail plane would be 'floating'. It would still fit but the packing will help make a much more substantial joint whilst keeping the line indicated and leading edge in the correct position.
        • Gern
          • 9213
          #64
          If that's the only 'fix' you've got to do with this one Steve, I wonder if all the critics of this kit were actually building the same one! That's a beautifully clean build so far.
            • 22770
            #65
            I have to agree with Dave there Steve, some Stirling work. I'm enjoying watching this one come together.
            • rickoshea52
              • Dec 2011
              • 4076
              • Rick
              #66
              It's interesting that you will build a Do-335 next, one of these crashed in 1946 just a couple of hundred yards from my house (before it was built) onto the grounds of Cove Juniors, my daughter is a pupil there. This month will be the 70th anniversary.
              http://aviation-safety.net/wikibase/wiki.php?id=74662
              • stona
                • Jul 2008
                • 9889
                #67
                Alan Hards was killed in the crash of a Do 335 A-10, W.Nr. 240112, which we had acquired from the Americans and given the Air Ministry number AM 223. It was a two seat trainer version. It was flown back to the UK and first flown at Farnborough by Eric Brown who observed the fatal crash on 18th January. Brown reckoned that had Hards, who was aware he had a problem, though not a fire, landed immediately rather than making a circuit of the airfield he may have got down safely. The cause of the fire was a faulty sparking plug which had blown out of the engine, subsequently the elevator control system burnt through. The problem with sparking plugs and rear engine fires had plagued the Germans too.
                The second Britsh Do 335 (W.Nr. 24016?) was a single seat version given the Air Ministry number AM 225. It never made it to the UK following problems on ferry flights and was scrapped, in France, at Merville.
                I'm not sure which aircraft I'll do, but it will have to be a 'zerstorer' version.
                • stona
                  • Jul 2008
                  • 9889
                  #68
                  Originally posted by \
                  If that's the only 'fix' you've got to do with this one Steve, I wonder if all the critics of this kit were actually building the same one! .
                  I don't know Dave. As far as I'm aware the basic plastic is the same across the range. My version has a few extra sprues for tropical bits etc, but that's the only difference. I hate to go on about it, but maybe the problem lies in the instructions. It's one of those kits where you really must plan and fit several steps ahead or you will find stuff not fitting. The instructions don't show a good order to build in, nor the relationship of some sub-assemblies to the overall kit. It would be easy to get the engines out of line in the nacelles for example, as some have done. The kit shouldn't be a problem for a reasonably experienced kit maker, but for a relative novice, or for someone less familiar with aircraft kits, I can see where it could all go wrong!
                  I always try to build cleanly (with varying degrees of success!). If a kit looks okay before its painted it should look okay under paint.
                  Thanks for the nice comments everyone. I'm really trying to get a shift on with this one whilst I have some down time. Mind you, me going fast is still slow by most people's standards
                  • stona
                    • Jul 2008
                    • 9889
                    #69
                    I've started priming the kit, here's the underside.
                    This hasn't revealed any issues, however my inability to fine the underside colour (RLM 78) which I ordered from Sovereign Hobbies (who now carry the Colourcoat range) might be a problem. I ordered it along with some other colours before Xmas, but the whole order has gone awol in chateau Stona ): I'm hoping that it has just been misplaced in the Xmas chaos!
                      This is looking great so farbut then would not expect anything less than that from you.
                      Scott
                      • stona
                        • Jul 2008
                        • 9889
                        #71
                        Hooray!
                        Also found some aluminium paint, which I need, in the same package.
                        • BarryW
                          • Jul 2011
                          • 6010
                          #72
                          Totally agree with Steve. There are no significant fit issues at all, the plastic is superb and the shortcomings are in the instructions and the decals (which were very basic on mine). For the exhausts Steve, on mine I used plastic card blanks to fit them leaving the engine out and used the Quickboost resin that are a big improvement over the kit parts. I also used plastic card to help create better/stronger joins.
                          A great build this Steve
                          • stona
                            • Jul 2008
                            • 9889
                            #73
                            Thanks Barry. I will probably use the kit parts as I want to do this OOB. I'm trying to go 'cold turkey' on after market parts with only moderate success so far! Hopefully all I'll need for this is a couple of swastikas
                            Believe it or not I haven't actually checked the decal sheet yet. I generally take sheets out of the kit box and put them in a freezer bag which is then filed (in random order) in a red file box. There's less chance of them being damaged or getting something spilled on them.
                            • Gern
                              • 9213
                              #74
                              And of course finding them later gives you something to do while you're waiting for your paint to dry!
                              • yak face
                                • Jun 2009
                                • 13840
                                • Tony
                                #75
                                Looking really nice steve, cant wait to see the paint go on. cheers tony
