Rick's Airfix 1/72 Avro Shackleton MR2
  • simno9
    • Aug 2014
    • 26
    #61
    I have seen on another forum a method where you dip cotton wool in boiling water and use this to press the decal down, the heat helps the decal to conform to whatever's under it.  Rubber gloves are recommended and I use the little circular pads of cotton wool that are sold for removing makeup.  I've used it few times fairly successfully with Airfix decals though never on anything as big as that fairing under the roundel.
    Hope this helps,
    Simon
      • 18272
      That is just nasty. The hot pad might work but I see cursing in your immediate future...
      I normally resolve my issue s with micro-sol and or warm water, but I've never seen one that bad.
      • flyjoe180
        • Jan 2012
        • 12463
        • Joe
        • Earth
        #63
        Oh dear, that's a tricky one Rick. First thing that came to mind was to cut the GT from the white number panel. At least then you can manipulate that part over the bulges a bit easier. After that, not sure, maybe cut and place in pieces, filling with paint as required? The hot pad idea is worth a go I suppose. Lots of decal solution... Or paint that white panel and place the numbers on it individually.
        • rickoshea52
          • Dec 2011
          • 4076
          • Rick
          #64
          Some careful cutting with a scalpel and plenty of decal softener has made a big difference but I still have some silvering and it isn't really that neat. Some paint touch up will be required.
          • flyjoe180
            • Jan 2012
            • 12463
            • Joe
            • Earth
            #65
            Is ti possible to repaint in between the GT letters Rick? Hopefully you can fill in the white bits easily enough with white. Bit of a nightmare decal that one!
            • colin m
              • 8804
              • Colin
              • Stafford, UK
              #66
              With a very sharp blade, stab all the silver bits, then apply the decal softener of your choice. I had a similar problem on my Shackleton (Revell)
              • rickoshea52
                • Dec 2011
                • 4076
                • Rick
                #67
                I've done this already (it was actually much worse) but as you can see it will need another go to clear it up. The macro on the camera is brutally honest isn't it!? I'll get there.
                • colin m
                  • 8804
                  • Colin
                  • Stafford, UK
                  #68
                  Yes the camera shows so much more than we can see. Well the next step maybe to weather it to death !
                    • 18272
                    How about if you carefully cut all the clear film with a new blade, the soften it with decal solv and peel it off while wet. As for the white decal I'm sure a careful touch up will cure that.
                    • rickoshea52
                      • Dec 2011
                      • 4076
                      • Rick
                      #70
                      Now that my Mig-21 & Dauntless are off the bench I have picked this up again, actually I have been picking at it here and there. So, touch up of the roundel has been done along with finishing the full decal set, other work includes sealing coats of gloss and Matt varnish, a pin wash and exhaust staining.
                      Lots of appendages have also been done - flaps, main landing gears and doors and of course the wings and tail planes.
                      [ATTACH]274132[/ATTACH] [ATTACH]274133[/ATTACH] [ATTACH]274134[/ATTACH] [ATTACH]274135[/ATTACH]
                      • Vaughan
                        • Apr 2011
                        • 3175
                        #71
                        Looking good Rick. the decals have come out well despite your initial problems. Looking forward to your complete photos.
                        • colin m
                          • 8804
                          • Colin
                          • Stafford, UK
                          #72
                          Oh yes, I remember this. Nice to see it on the move again.
                            I prefer to press down the decal not too softly but a little aggressively without damaging it to force out all water and air using a cotton bud. I then liberally apply decal sol by micro scale industries. This works a treat for less conforming decals such as Trumpeter. My latest 1/32 Trumpeter Bf 109 G-2 worked really well with that approach. Btw, I love your work on that shackelton. looks a beast
                            • flyjoe180
                              • Jan 2012
                              • 12463
                              • Joe
                              • Earth
                              #74
                              This is coming along very nicely Rick, looks like you conquered that decal issue.
                              • rickoshea52
                                • Dec 2011
                                • 4076
                                • Rick
                                #75
                                I'm still chipping away at this, the masking has been removed from the transparencies and a bit of touch up has been done. Unfortunately the yellow dotted line decal around the pilot's side windows came away with the masking tape.
                                The bomb doors and wheels are also fitted - note to fit the RH door in the RH side!
                                I am tantalisingly close to the finish with some aerials remaining and the weapons load though I am contemplating displaying them on bomb trolleys next the the Shackleton - I am going to pose the model on the base I made for my Nimrod a while back.
                                [ATTACH]275345[/ATTACH] [ATTACH]275346[/ATTACH] [ATTACH]275347[/ATTACH]
