Hasegawa 1/48 F-86f30
    Another very nice kit grom Hasa, the detail and dryfit seems very nice....however the bangseat was a huge letdown. There is no belt detail or anything like that, not even the prominent red armrests.
    I added them from balsa, aswell as the seat pan padding and made belts from lead foil.
    The Instrument pannel is the supplied decal, I just added drops of future in the bezelfaces to look like glass.
    Theuns
    A little update....
    Theuns
    • Robert1968
      • Mar 2015
      • 3596
      Looks a nice kit
      I like the office and what you've done to it makes it look that much better, nice touch on the glass look
      Looks like it's very well panel lined
      Regards
      Ronertv
        • 22788
        Just seen this one Theuns nice work on the pit. Looking forward to more
          Nice detail in the speedbrake and wheel wells.
          • colin m
            • 8800
            • Colin
            • Stafford, UK
            Indeed, good detail, well highlighted.
            • Robert1968
              • Mar 2015
              • 3596
              This I looking very nice so far ( liking the office detail )
              I'm looking for a number 2 jet to do once I finish my GB build. The Sare looks a nice kit
              Regards
              Robert
                • 22788
                Nice work Theuns
                  I use tamiya gloss black enamel as my alclad base, I also shoot on a coat if neat turpentine over the whole thing to smooth out the paint and save me from having to sand it.
                  Theuns
                    Nice looking build so far Theuns
                      • 22788
                      That's looking very nice and shiny Theuns
                      • Robert1968
                        • Mar 2015
                        • 3596
                        Nice and shiney ( hope you put it in a container ( stop the dust )
                        Looking good
                        Robert
                        • flyjoe180
                          • Jan 2012
                          • 12463
                          • Joe
                          • Earth
                          Nice work so far Theuns. Lots of Sabres coming out of the woodwork. Not heard of shooting turpentine over enamels to smooth it, guessing you'd have to be rather careful with that mixture?
                            The turps trick is just something I have tried because I didn't want to sand the model smooth, it rarely works out well.
                            It is very hot here lately when I sprayed so I flood the turps on and then keep rotating the model so it can flow out nicely. It just takes out the rough texture, it does not really thin the paint all the way down to the plastic.
                            Theuns
                              Here it is in 3 coats of airframe allu. I usually at this stage mask off the panels I want to look a little darker and shoot more alclad to make the rest lighter.....I now have 2 ways to go with this model
                              1. the decals are for a nice 1960's plane in the normal "used" NMF
                              2. I have a pic of the same plane as a super pollished airshow plane, where basically only the gun panel and exhaust looks a little darker, the rest of the metal looks uniform due to the pollishing.
                              What to do what to do.....
