tamiya 32 scale p51d mustang
    I am impressed! Verry good job!!!
      Some lovely work going into this Roger.
      I do like all the work you have put into the cockpit.
        Thanks guys there is so much more detail than 48 scale and I'm a bit of a critique of my own stuff coupled with it being probably my favorite aircraft I have to give it my all
        Roger
          Need a break from the cockpit just for a while so had a go at the wing gun Bays I added some more photo etch to represent the lower wing skin and the front main spar and rear spar also rear gun brackets I'll probably spray silver then tamiya yellow green then scratch up a bit not sure yet
          Roger
          • flyjoe180
            • Jan 2012
            • 12433
            • Joe
            • Earth
            #35
            Roger, this Barracuda resin upgrade may help with your wiring question? http://barracudacals.com/images/instructions/BR32014%20P-51DCockpitUpgrade.pdf
              Thanks I'll give that a try
                Yes all the info is there thanks for that Flyjoe
                  I love what you are doing here! I will watch this build staying in shadow , silent....Sssts.....
                  • Pikeman
                    • Feb 2016
                    • 1312
                    #39
                    Looking great Roger
                    keep up the good work .
                      Just painted guns satin black then drybrushed with gunmetal airbrushed the bays and gave them a wash of burnt umber next up the troughs for the ammo belts I have a choice here of kit plastic or photo etch not sure which to use yet it's down to which machine gun rounds look best once painted
                      Roger
                      • Pikeman
                        • Feb 2016
                        • 1312
                        #41
                        Roger
                        Still looking good Roger.
                          Nice work in the gun bays Roger.
                            The detail is amazing
                              This kit has so much more detail than the 48 scale tamiya kit but it's not without some issues mainly the radio is the wrong way around if you follow the instructions and the battery is too far to the left looking from the rear only about 4 mm but that's throwing other things out
                              The fit of all the parts is terrific it could not be better I have decided to use the kit ammo belts as they are better than the photo etch stuff
                              Going to go back to finishing the cockpit next as I want to get the fuselage glued up together and there is still a lot to do first
                              Thanks guys for following the build I do find it a great help and encouragement
                              Still not quite sure which one I will do but it will be an early one as the instrument panel and lack of fin fillet dictate this version
                              Roger
                                sorry it's been so long guys had a MacDonald burger Friday and ended up with food poisoning on the mend now
                                Made a start on the wheel wells added some wiring next up will be all the hydraulic lines
