I'm not sure the price of kits puts younger people off the hobby, there are plenty of cheap entry level models around, a position in the market that I think Airfix occupies. Maybe kids do have better things to do with their time but as an example, how much does a games console cost and each new game that is released to go with it.
That's a fair point.
I suppose there is a lot more choice than there was 40-50 years ago. Speaking for myself, if it was raining there was scalextrix or making a model, if it was nice out, then indoor pursuits were definitely put on hold This is before beer and girls entered the equation!
I did not get a lot of time at the bench over Friday/weekend (but I did book a test drive for a new car and, the missus agreed to a 55 inch 4K TV and soun bar plus new blue-ray - and ordered it all!!!)....
Anyway - here is my progress to date:
The above need to be masked tonight, I will then be doing washes and dry brushing on the tail wheel assembly.
below is the canopy all masked up. Yes, it will be a while before I apply paint but with such a large model it is easier to get this done now rather than when to main build is completed.
I really do recommend the Eduard masks for this, its worth it. The canopy framing is quite complex and using ordinary tape would drive you mad! I will also tonight trim the liquid mask with a knife in a few places where it needs it.
I first of all used some Mr Surfacer 500 on the tail joins. The fit is good so only a little was needed I then did the did i.p.a. trick (which works with other Mr filler products and Vallejo Plastic Putty). I dipped cotton buds into ipa and rubbed the filler removing excess in a way that does not damage detail and is a lot easier than sanding.
I then used these to weather the tail wheel.
The result the detail pops out. I did some drybrushing with a metalliser as well on the strut.
I am not very pleased with my photography, I apologise for that but I just have my iphone. One of these days I will get a better camera and will learn to use it.
I made a start on the undercarriage last night. It was delicate work as the parts are quite fine. The clean up was minimal though and the scrapers helped a lot. There are some angles that will need to be achieved with the struts so I made sure some parts are not cemented in position.
when fitting the pipe work a piece pinged off the tweezers never to be seen again.
So out comes the lead wire which is exactly the right circumference.
below is the cut piece in situ and it is spot on I am rather pleased with it
D20 in the instructions is the piece in question
Done, the long strut is not cemented in place as is the odd shaped part hanging off it
that was an hours work which was the my whole seasion last night. Four more legs like that to do !
I built up another leg... but had the same problem as before, with the same equivilent part...so out comes the good old lead wire.....
Also started pulling together other pieces for the wheel including the wheel itself, all now awaiting clean-up...
I glued together the forward and rear fuselage sections. A piece of tape and gravity is holding them in exactly the right position while some Mr S Cement was used sparingly in a couple of places clear of the tape to pin them together. Tonight I will remove the tape and the clamps to run Mr S around the joint and inside to make sure it has a good bond. It is exactly like Tamiya Extra Thin, but better, using capillary action - I use it for 90% of my glueing.
