**SCRAPPED**Hobbyboss 1/48 Ta 152C-1+Eduard PE
    The Ta 152 was the best piston engined fighter of WW2, but sadly did not see mainstream prodution. Designed by Kurt Tank of Focke Wulf, this was a thoroughbred of the Fw 190D-9 fighter
    The C-1 version was the most heavily armed variant.
    I am now building this aircraft, this is by Hobbyboss and in 1/48. Fit is generally good and the cockpit is shaping up rather nicely. However, they should had provided more sidewall detail, but the eduard PE supplied some. The Main control stick is yet to go on.
    Criticism is welcome
    I didn't superdetail it as the cockpit is very enclosed.
    The same is for the half engine plug
    Cheers, John
    That looks very nice to me John. You're right about the cockpit, it's very hard to see into once its built.
      After some work, this has come along rather nicely. The fit is excellent
      Some wiring was added to the engine, but was kept to be minimal, as the engine's view would be extremely minimal.
      The cockpit was finished off, and extra detail was extensively added, but unfortunately, only a quarter of it was seen,
      NOTE The assembled images are of a dry fit
        Yes, quite disappointing when you build it up and little of it is seen
        • dave
          • Nov 2012
          • 1828
          • Brussels
          At least you know the detail is there John.
            yes, but some of the engine plug and wiring will be visible through the wheel wells which will be interesting to see
              This was actually the original aircraft, the Ta 152V6. It never got past prototype stage It was named VH+EY, a classic prototype name for experimental aircraft
              I will be posing it exactly like this, with the cooling gills open and the canopy open as well.
              • Pikeman
                • Feb 2016
                • 1312
                Looks like you have done your homework on this one,off to a good start it's looking great
                  Thanks mate
                  Did some progress on here. The undercarriage wiring and oleo sissors are notoriously difficult to fit, due to the fiddly wiring and the two part nature of the oleo sissors.
                  Extra yellow wiring was added into the Undercarriage bay and the fuselage was mated together, and the same was done for the wings. it was then sanded down and the panel lines were rescribed using an RB productions scribe R. Washes were liberally applied to the inside of the undercarriage.
                  ALL ASSEMBLED PICS ARE OF A DRY FIT
                  Cheers, John
                  The undetailed undercarriage
                    This is looking great so far john nice clean build.
                      • 22770
                      Just seen this one John and it's looking very good indeed.
                      • flyjoe180
                        • Jan 2012
                        • 12400
                        • Joe
                        • Earth
                        Yep, agree with Ian, this is looking great
                          The fuselage, upper cannonbay, nose and wings were mated together to the main fuselage today. The fit was good, but not perfect, and marginally needed some filler along the wing roots. However, the cannonbay's fit overall was pretty good.
                          This was followed by a priming coat of Mr Surfacer 1000 followed by pre shading in Gunze Mr Hobby Tyre Black. The pre shading was deliberately wavy, as a judge at a model show once told me that once the paint went on, it would break up the surface and make it look more natural. I don't how true this is, but I am about to find out.
                          I purchased some hollow aluminium tube and replaced all of the guns with it and in my opinion, were a definite improvement over the stick like kit ones.
                            Some good progress there John. I'm glad that pre-shading can be wavy, coz mine always is!
                            • colin m
                              • 8750
                              • Colin
                              • Stafford, UK
                              All looking very nice. But just look at how far back the pilot sits. This must have been a bit of a nightmare to taxi.
