I've joined the fuselage halves without too much drama.
Some of the parts aren't quite as drawn in the instructions and there are quite a few locating bits which are drawn but don't exist on the parts which makes life interesting! To get the cockpit framing at the correct height I made some locating tabs of my own (invisible now, that's the point!)
This does mean that some of that cockpit tubing extends below the fuselage.
This is realistic as the top of the wheel well forms a 'floor' under the cockpit tub. There were even a couple of cut outs so that the pilot could visually check the undercarriage position. It did however make me check the fit of my resin wheel well insert, once dry fitted to the lower wing centre section. The result is that I have had to thin the top of the resin insert until it is paper thin and translucent. It does now fit.
It's the sort of thing you have to check with these kits, it's only a problem if you don't
