FINISHED Eduard 1/48 Focke Wulf Fw 190D-9 Profipack
    I have had the Eduard 1/48 Focke Wulf Fw 190D-9 Profipack LATE version sitting in the stash for a bit now, and I have bought the standard version of Eduard 8184 Profipack Focke-Wulf Fw 190 D-9 along with the Eduard 1/48 Spitfire Mk IXc late Proipack, so I pulled this out as a replacement biuld for my scrapped Ta 152.
    As with all Eduard Fw, they are fiddly, but worth the effort. Careful effort and joining is going in as parts placement is vague and fit is precarious. However, the parts are exceptionally detailed.
    I just got the pit and the bare foundations of the forward cannon bay housing the MG 151s done tonight. Hopefully, the cannon bay, engine plug and root wing canons will be finished off tomorrow.
    For now that will be all until tomorrow.
    Cheers, John
    All the Eduard 190s are lovely kits, even if somewhat complicated to build. As you say John, careful test fitting usually sorts out any problems.
    That cockpit looks very nice, fingers crossed that this one doesn't go the way of your 152
      thanks mate, thats the plan.
      and yes, although they aren't the easiest kits to put together, they can produce stunning results when test fitted and carefully checked before committing to glue
      • dave
        • Nov 2012
        • 1828
        • Brussels
        Nice start on the cockpit.
          Very nice looking cockpit.
            • 22770
            A great start John and a very fine looking cockpit.
              Very good start
              • monica
                • Oct 2013
                • 15169
                nice work on the cockpit so far,
                  Next update. The forward cannon bay and cockpit has been completed. The engine plug took me a solid 2-3 hrs, trying to align things up well so everything would match up. However, this paid off as the engine plug and cockpit slid in without too much problem. The wing root cannons also slid in fairly well after careful alignment. Moulded detail was excellent, with ignition leads for the machine guns moulded in place along with the junction boxes. Overall, despite it's complexity, the kit displays brilliant detailing. A pity they did not provide a full engine bay though. Wing ribbing was also attached to the undercarriage. The root wing cannon bays were also dry fitted with the wings before glue, then was glued.
                  Cheers, John
                    new update. I dry fitted the wings to the fuselage and filled a gap along the spine. The fit along the wing roots seem to be very promising. The wing root machine gun ports were also washed and weathered appropriately. Unfortunately, I did find a gap on the underside, but nothing serious in terms of filling. More progress will follow tonight.
                    Cheers, John
                      I think you're really nailing this one John. Although all of the Eduard 190s I've seen built had a slight gap either at the front or rear of the lower wing.
                      Looking forward to seeing the paint go down.
                      Patrick
                        Patrick
                        Thanks mate, the fuselage to wing root join was pretty smooth, with no problems whatsoever. However, I ran into trouble on the upper cowling, but fixed this up pretty quickly with some filler. There was a hairline crack on the lower surface of the fuselage, but again, this was fixed with filler.
                        I decided to do one open root wing cannon bay and do a closed one on the other wing. Everything which was filled was then sanded smooth. Tomorrow a thin layer of primer and then paint will go on. I removed the kit wing cannons and replaced them with hollow aluminium tubing which substitued it very well, with a very pleasing effect.
                          Meanwhile, I did some research on this aircraft. Yellow 15 was a Fw 190D-9 of a "Wilde Sau" squadron of Jagdgeschwader 301, which worked on the principal of free roaming in the crowded air over germany in "Reich defence". Yellow 15 emergency landed at Erfurt. It was part of 9. Staffel of JG 301.
                            Nicely painted details.
                            • stona
                              • Jul 2008
                              • 9889
                              'Wilde Sau' was a term for freelance night fighters. This was a concept promoted by Hajo Hermann, he convinced the Luftwaffe to allow him to establish a single engine night fighter test detachment in late April 1943. In JUly 1943 this developed into 'Herrmann Geschwader' code named 'Wilde Sau' in July that year. It was subsequently renamed JG 300.
                              JG 301, all three Gruppen, was formed during October 1943. They operated as single engine night fighters but by early 1944 they were operating by day and night. Later they were committed to daytime missions against the Americans. I don't think they were flying as night fighters at all by the time they received D-9s and later Ta 152s.
