Italeri 1/48 Lysander
  • Dave W
    • Jan 2011
    • 4713
    [ATTACH]32226.vB[/ATTACH][ATTACH]32227.vB[/ATTACH][ATTACH]32228.vB[/ATTACH]
    I thought i would build this next and take advantage of all the info generated by Vaughans excellent build of the 1/32 version.This ones an ancient Testors kit reboxed by Italeri.There's hardly any interior detail so i bought a superb Eduard etched set for it.It only cost around 6 quid so is a cheap way of tarting up an old kit.I love the bit in the instructions that tells you to use a rather lethal looking pair of scissors to open up holes in the fuselage for the crew ladder!.
    [ATTACH]37136.IPB[/ATTACH]
    [ATTACH]37137.IPB[/ATTACH]
    [ATTACH]37138.IPB[/ATTACH]
  • Dave W
    • Jan 2011
    • 4713
    There are no lights in the kit for the wheel spats.And as can be seen in the first photo there isnt any provision for fitting them either.So i thought i would have a go at making some. What i did was make some holes in a piece of plasticine and fill them with two part 10 minute epoxy glue that dries clear.I them cut out holes in the wheel spats and fitted the lights.Finished it off with retaining rings included on the Eduard etched fret.I know they are not mega detailed but they look better than just painting them on as suggested by Italeri.
    • Vaughan
      • Apr 2011
      • 3174
      Hi Dave
      Sounds very ingenious creating the landing lights. Unfortunately the attachments you have posted aren't working so I can't see how it's coming on. I hope you can sort the images out.
      Vaughan
      • Dave W
        • Jan 2011
        • 4713
        Sorry,I will post them again tomorrow night when I can get back on the family computer.I still find posting on the forum a hit and miss affair.Works every time on my iPhone.Unfortunately my phone won't let me post pictures.
        • yak face
          • Jun 2009
          • 13841
          • Tony
          Nice looking project dave, the etched set will improve things no end. Just be careful with those scissors-no running! cheers tony
          • Dave W
            • Jan 2011
            • 4713
            These are the photo's i tried to post last night . They are of my attempt at scratch building the landing lights.Something that is not included in the kit.I came up with the idea of casting some from clear two part epoxy glue.Unlike most of my ideas i think this ones worked.They are not super detailed but i think they look better than just painting a silver dot on the wheel spats. [ATTACH]32271.vB[/ATTACH][ATTACH]32272.vB[/ATTACH][ATTACH]32273.vB[/ATTACH][ATTACH]32274.vB[/ATTACH][ATTACH]32275.vB[/ATTACH]
            [ATTACH]37166.IPB[/ATTACH]
            [ATTACH]37167.IPB[/ATTACH]
            [ATTACH]37168.IPB[/ATTACH]
            [ATTACH]37169.IPB[/ATTACH]
            [ATTACH]37170.IPB[/ATTACH]
            [ATTACH]37171.IPB[/ATTACH]
            • Dave W
              • Jan 2011
              • 4713
              Dont know whats gone wrong with my post.The thumbnail is the kit part before modification.
              • Vaughan
                • Apr 2011
                • 3174
                Hi Dave
                I'm impressed they've come out really well!. looking forward to the next stages.
                Vaughan
                • colin m
                  • 8755
                  • Colin
                  • Stafford, UK
                  Great subject, between Vaughan, you and me, we'll have all three scales covered.
                  Colin M......
                  • Dave W
                    • Jan 2011
                    • 4713
                    [ATTACH]32551.vB[/ATTACH][ATTACH]32550.vB[/ATTACH][ATTACH]32549.vB[/ATTACH]Made some progress with the Lysander.Fitted the PE framework to the fuselage halves .Also folded up the PE part that makes up the framework behind the pilots position.To this i've attached the PE seats,harnesses and kit fuel tank.The engine is only half an engine on a flat plate.But after a bit of painting its come out ok.I've painted and attached the the rear gunners ammo drums to the rear shelf as well .I found the rear gunners seat difficult to build.It looks straight forward but i had to cut two pins to length then fold a piece of PE and attach everything together.I managed to stick my fingers together with superglue,but would the parts stick together?!.Eventually i used two part epoxy (as Trey once suggested to me) and that did the job[ATTACH]32552.vB[/ATTACH][ATTACH]32553.vB[/ATTACH]
                    [ATTACH]37393.IPB[/ATTACH]
                    [ATTACH]37394.IPB[/ATTACH]
                    [ATTACH]37395.IPB[/ATTACH]
                    [ATTACH]37396.IPB[/ATTACH]
                    [ATTACH]37397.IPB[/ATTACH]
                    • Vaughan
                      • Apr 2011
                      • 3174
                      Hi Dave
                      It's looking good coming along nicely PE parts certainly finish it off gives it that extra detail that the kit would have been missing. The engine despite only being as you say "half an engine" still looks authentic. Keep the good work up. I'm looking forward to the next stages.
                      Vaughan
                      • Dave W
                        • Jan 2011
                        • 4713
                        Made a bit more progress with the Lysander.I've fitted the PE and kit parts to the cockpit.After an hour or so of masking i've glued the front canopy section to the model.I was going to leave the wings off to make painting easier.But like a little boy i couldnt wait to see it with the wings fitted!.So they are now glued on.Im going to paint this one as a Free French machine used in Tunisia in 1942.Apparentely 25 Lysanders were transfered from the RAF to the Free French airforce.They were used mainly for reconnaisance,but sometimes for bombing.So i shall be fitting the bomg racks to the undercarriage legs.Italeri give the colour scheme as green and brown upper surfaces with light grey undersides.I cant find much info on the internet so will probably go with dark green,dark earth and sky.Im guessing they would still be in RAF colours .Unless anyone else knows different?.This model should have fairings over the cylinder heads on the engine cowling.The instructions show them as seperate items to be fitted .But there are none in the kit. t[ATTACH]32717.vB[/ATTACH][ATTACH]32718.vB[/ATTACH] [ATTACH]32719.vB[/ATTACH]
                        [ATTACH]37545.IPB[/ATTACH]
                        [ATTACH]37546.IPB[/ATTACH]
                        [ATTACH]37547.IPB[/ATTACH]
                          Dave this is looking real good getting me motivated to crack open mine!
                          • colin m
                            • 8755
                            • Colin
                            • Stafford, UK
                            Looking great Dave, I think I have a bit of a soft spot for 'ugly ducklings' !
                            Colin M........
                            • yak face
                              • Jun 2009
                              • 13841
                              • Tony
                              Top stuff dave, its coming on great. I would imagine that the aircraft would be in standard RAF dark earth /dark green/ sky, although i have seen a profile of a free french one in a strange sand/brown/green/ with azure blue undersides! As for the bumps on the cowling they are only very slight, i imagine carefully placed drops of pva glue would give the effect , im sure with your skills it wouldnt be any problem. cheers tony
