Tamiya 1/32 Spitfire Mk XVIe
    This has come along great mate. Looks amazing.
    • BarryW
      • Jul 2011
      • 6032
      #92
      Well - its done and I will open a Completed thread but a couple of final pics on this thread.
      Bombs fitted.....  pity abouj the rubber tyres, one of the few weak spots.
      Canopy fitted
      And - here she is...
      To summarise - a great model truly deserving its reputation and the best Spitty model you can buy.
      OK - its not perfect...
      I dont like the toy like aspects that simply complicate the build, I will say more about that on the completion thread.
      The rubber tyres are poor - I will get resin for the next two Tamiya Spitty builds with a mk IX and Mk VIII in the stash.
      The cockpit door is a weak spot as well - I may get resin replacements but this is not a major issue.
      But - it is well engineered, the fit is outstanding and, while complex, it is not a difficult build and where you get a problem the fix is easy.
      As for the new materials I used in the build...
      The metal powders from Ushi and MIG are a revelation.  I would not do an overall NMF with it but for detailing, weathering and dry brushing simply superb.
      The Windsor & Newton varnish - well I have mixed feelings as it sprays well but it takes a long time to dry and even longer to fully cure.   The varnish had not hardened proberly after 24 hours and when working on the model I found it had rubbed away in places and needed some touch up respray.  The varnish worked best unthinned by the way, using a .4 needle I used 25-30 psi.  I expect it will dry the a good hard finish over several days.  I will return to using AKI's varnish with the next build.
