Hi Matt just a quick tip with filling joints which i was told about on this forum when filling put some masking tape on each side of the join then put the filler in and before it drys take the tape away less to sand down and a lot neater looking hope this helps
A first go
OK, I think this kit is as done as it's getting - it's just waiting for some less soggy weather so I can take it out in the garden and spray varnish it. I'll upload some final photos once that's done.
In other news, while looking through the debris of our house-move I found a couple of untouched kits and a half-built one, bought in a fit of enthusiasm at an airshow a number of years ago. There's a Hasegawa 1/72 Me262, the Postwar Czech version, an Airfix (?) Mistel in 1/72 and a half-built Heinkel 70 which I think is a Revell kit. Instructions and decals are long gone and there's poly cement thumbprints all over it, so I may just use it to practise filling and sanding and that kind of thing.Comment
Matt, I've been looking at the pictures of your model and the posts and I see you have brush painted it.
I only brush paint my models and the following might be of help:-
Firstly, everyone please understand I am not being critical just trying to help. I noticed a few brush marks on the wings, this is due to applying the acrylic too thickly. Now you have practice pieces, thin the paint down using water (try 50/50 as a start and alter as you see fit) some folks use distilled but I find it makes no difference.
Then apply successive coats, as you know the paint dries quickly so you don't have to wait long between coats. Continue coating until you are happy with the results....
RonComment
Thanks, I'll try that next time. This is the whole point of the thread, for people to tell me what I could be doing better.
It looks like the postwar Czech Me262 is going to be all-over natural metal finish, so I may splash out on a rattle can of the appropriate colour for that one.Comment
Glad my little input will be of some use.....Also, I have tried all acrylics with my brush painting. The only ones that give me the results I want are Vallejo Model Colour. For detail work I use Humbrol enamels
Have a look at the Scale Models shop.
RonComment
[ATTACH]32781.vB[/ATTACH][ATTACH]32782.vB[/ATTACH][ATTACH]32783.vB[/ATTACH]
Here as promised some photos of the finished item. It's not the best model on the forum, but it's pretty if you don't look too closely, and the Irish markings are both colourful and unusual. It's by some distance the best job I've made of a kit, as well.
I think the grey of the camouflage is a bit dark, so if I do the RAF grey/green scheme again I'll lighten it a bit. I also used a bit of artistic licence on the prop spinner. The box said duck-egg green, another source I've seen suggested an orange band at the base, so I made it a tricolour. I found out in the process that painting straight lines on a prop spinner is hard.
Things to remember for next time:
- Miniscule amounts of filler go a long way. Mask either side of the join so you don't get big blobs.
- When painting with acrylics and brushes, thin them and build up several coats to avoid visible brushmarks.
- Doesn't matter how steady your hand is, you can't paint straight lines freehand. Mask it.
- Plan ahead rather than stumbling over problems.
I got the Hasegawa Me262 out and had a look at it, but it looks like such a nice detailed kit I don't want to waste it on practice, so I'll be heading back out to the shops again to pick up something else cheapish.
Next time out, as well as improving on technique, I want to have a go at doing more cockpit-wise (instead of the standard issue seat-stuck-to-a-plank); try out a radio antenna wire and do some weathering. Will also give the Vallejo paint range a crack.
[ATTACH]37593.IPB[/ATTACH]
[ATTACH]37594.IPB[/ATTACH]
[ATTACH]37595.IPB[/ATTACH]
Hi matt , nice hurricane, great to see some different markings too. If youre wanting a cheaper kit to have a bit of practice but still be a nice build,how about some of the academy 1/72 stuff. You can get them for around £6 and they build up lovely, in fact i think john has just got some in at the scale models online shop. On the subject of brush painting with acrylics rons your man , and something else to consider is the games workshop paints - they brush great ,the only slight snag is that they arent standard colours so you have to either mix to match or go for the nearest colour, but i can vouch for the quality and ease of brushing, ive used them quite a bit. heres to the next one, cheers tonyComment
It's more the fact it's what I've got in, but they are nice to work with. I know what you mean about the colouring - but that said, I thought the Catachan Green and Codex Grey (underside) looked about right colourwise, it was just the Adeptus Battlegrey foundation that was a bit on the dark side for the grey camo. And actually, that seems to have lightened a bit under the influence of two coats of Klear and a spray of matt varnish...Comment
There are some cracking names. Tentacle Pink is one of my favourites. And Tin Bitz, which is a sort of "Rusty metal" paint that's ace for doing those not-very-well-cared-for metal parts.Comment
I always use mithril silver ,chain mail and boltgun metal for small areas of silver and the skull white and chaos black are always useful. Loads of these paints were given to me by my son and i liked them so much for brushing small areas , i keep using them. My own fave names are snot green ,rotting flesh and vomit brown!!!!! tonyComment
Originally posted by \Are you two speaking in code or something..............snot green, rotting flesh...................good lord !Comment
