Revell 1:32 He 111 P-1
  • colin m
    • 8755
    • Colin
    • Stafford, UK
    Well, as if a 1:24 Spitfire wasn't big enough, here is Revell's 1:32 He 111 P-1. A well known aircraft and well known model. It's been on the market for a few years now, its original price was around the £60.00 mark which isn't bad for a detailed model of this size. These days some people are asking around the £140 mark for this model - build it, maybe I should have sold it, mine cost less than £30. But no, that's not what we do here is it - we buy to build.
    So, the box.
    And the bits,
    No there are no sprue shots, too many and too big !  Also, an Eduard mask set, with so much glazing, I'm going to need a bit of help here. I've also bought the Eduard interior PE set along with HGW fabric belts. This aircraft flew with a 'green house' on the front so with so much visible, I thought I would do a bit extra in the 'pit.
    Cockpit detail is quite good in most places, but PE can make all the difference. So this is removed and replaced by the below.
    Other areas of the cockpit have the stock detail removed and replaced. Below is the cockpit slowly shaping up. Right now, I seem to be spending ages bending and shaping PE.
    Eduard instruct you to remove the rear cockpit doors and fit their own, this is then repeated on he next internal doors, so, do I go for internal lights ?? A lot will be on view.
    So this is what I seem to be doing nearly every night this week, bending metal. But hey, I haven't lost any yet.
    With so many little pieces to put together, I don't seem to be getting very far at the moment, but soon, I'm sure I'll get to stick something big together soon.
    Colin M..
    you'll need a hanger soon Colin. great start on this one will be watching it come a
      Hope you have the room, its a bbbiiiggg kit when finished.
        • 18270
        To big for me but I will enjoy seeing it being built here.
        • BarryW
          • Jul 2011
          • 6027
          Interesting to see this coming together and I admire your handywork with the p.e.  I have often had thoughts about the Eduard p.e. sets but I have never really got along well with p.e. generally and I also have doubts over how much can be seen and hence how much difference it will make to a completed build.  I will follow this with interest.
          • colin m
            • 8755
            • Colin
            • Stafford, UK
            It's a good point, how much difference will PE make. If you built this model, straight OOB, you wouldn't be disappointed, it has enough detail already. Also, I suspect, the overall size of the model is what will catch the eye, not the extra detail in the cockpit. So why bother ? well what I haven't shown yet, is the second, printed fret of PE. This stuff really makes a difference. I'm off work today (ma'am thinks I'm gardening) so hopefully might have some of the printed PE in place.
            Also, if you're not sure or having a bit of a problem with PE, 1:32 is a good scale to have a go  - it's big. I have used 1:72 PE before. At that scale, there are some parts I refuse to deal with - madness !
            When I bought this (it was cheap) I did think, 'What the hell am I going to do with it now' However, I bought it so long ago, daughter No.1 has grown up and moved out, hence my new space and home for my models.
            I found a pic on line of a little lad, must be 6 or 7 years holding one of these, it was about half his size !
            After this build Terry, I think I'll return to 1:48 / 1:72.
            • Dave W
              • Jan 2011
              • 4713
              I reckon the PE will make a big difference to the cockpit.In this scale it should be visible through all that glazing.Look forward to seeing more.
                If I were to build this I'd need to engage a divorce lawyer! Good luck Colin - the interior with its extra detail looks stunning so far.
                • colin m
                  • 8755
                  • Colin
                  • Stafford, UK
                  Cheers Doug. I think I'm ok at the moment, she has just bought me a cup of tea.
                  Well, the cockpit is generally together and painted. There's a lot of discussion around about which colour this should be, I've gone for this, RLM02, which turns might be wrong - too late now.
                  Some of the printed PE is now in place. Each of those little levers you can see, are separate components.
                  And finally for tonight. This harness is made out of 25 individual pieces which took me just under three hours to build and fit. I'm really happy there's no co-pilot !
                  So, that's it for tonight. I might have a little brandy after dealing that harness.
                  • tr1ckey66
                    • Mar 2009
                    • 3592
                    Very nice work on that cockpit Colin. Looking forward to seeing this come together as I've got a couple kits myself and really like the look of this kit.
                    The etch and the belts look great and really add interest to this very visible interior and the detail painting is terrific.
                    I think you're right about the colour - RLM66 would probably be the cockpit colour with an 02 fuselage interior. But I've heard talk of He111s prior to the BoB having an 02 cockpit so I think you're good. I had the same dilemma with my Stuka and went with 02 although I'm still not convinced with my decision.
                    Regardless, this is looking like the start of a really great build.
                    Looking forward to the next instalment.
                    P
                    • tr1ckey66
                      • Mar 2009
                      • 3592
                      BTW
                      I have read somewhere that some crews removed the cockpit doors completely for ease of movement through the aircraft. Which might aid visibility through to the bomb bay.
                      Just a thought...
                      P
                        Some very nice workmanship Colin. Great work on the PE. Used to hate the stuff but now i cannot get enough of it.
                        What is your technique for fixing the PE ?
                        • Snowman
                          • Oct 2014
                          • 2098
                          Amazing PE work there!! Really brings it to life!! B|
                          • colin m
                            • 8755
                            • Colin
                            • Stafford, UK
                            Yes, I'm leaning more toward 66 as being correct, but I actually like 02. Maybe I'll do the canopy framing in 66. I had read about 'areas forward of the pilot' being painted 66, maybe I can redeem myself this way !
                            CA glue. Although for the belts it has to be PVA to allow for shaping the belts into place. Which of course takes time to set.
                            Thanks Gavin. It can be a pain to use, but does bring things to life.
                            • colin m
                              • 8755
                              • Colin
                              • Stafford, UK
                              Well now, just a few ejector type 'things' to deal with.
                              Then a bit more photo etch, because I haven't used enough of this stuff already. This is a first for me. I've had to mask the windows on the inside of the fuselage.
                              Then, a bit pf paint. The pin marks are still visible, but I doubt will be noticed when it's all closed up. Well, hope so.
                              But at least the cockpit belts are all done.
                              Just a fire extinguisher (with PE bracket) and gun magazines (with more PE) to add to the cockpit. Those belts are great, but so fiddly, I'm not sure I'll use them again. I seem to have done a good few hours on this build so far, but a look to the floor on my right shows what's left.  I'm not sure I'm cut out for large scale planes !
                               Well, that's it for today.
