Revell 1:32 He 111 P-1
    Looking great, Colin. Commiserations over the Microsol/gloss coat debacle - what sort of gloss varnish do you use? I only really get tense while modelling during the gloss/matt varnishing stage - so much work to spoil if it goes wrong. Sounds like you recovered things well, though.
    • flyjoe180
      • Jan 2012
      • 12433
      • Joe
      • Earth
      #62
      Looks good despite the issue Colin.
      • colin m
        • 8770
        • Colin
        • Stafford, UK
        #63
        It was Humbrol clear. I've used it before many times with no problems. Anyway, I've just this very minute finished painting the damaged decals with my smallest brush before applying the mat coat tomorrow. The repairs are visible, but under the mat coat, I think will be acceptable.
          • 22771
          #64
          I always give the decals a light wash with warm water after using Set and Sol when its all dried Colin,
          • colin m
            • 8770
            • Colin
            • Stafford, UK
            #65
            That's something I've not bothered with before, but certainly will next time. Dealing with a reaction on a 1:72 model isn't too much of a problem. But at 1:32, everything seems so much bigger, including the problems !!
            • Gwyn
              • Dec 2015
              • 399
              #66
              Well done Colin, this is looking great and well worth the hours you have put into it.
              • colin m
                • 8770
                • Colin
                • Stafford, UK
                #67
                Thanks Gwyn, hours, yes its certainly had lots of those.
                So, decals are done and repaired (look closely at the number 3, slightly out of shape - but not too bad for hand painted). For a large model like this, it doesn't have too much in the way of decals. What it does have though are quite big.
                [ATTACH]270996[/ATTACH]
                • colin m
                  • 8770
                  • Colin
                  • Stafford, UK
                  #68
                  It's finished. So at last I can have a big tidy up. I have space again.
